Thread: 97 gtp fuel pump problem
Results 1 to 6 of 6
  1. #1 Re: 97 gtp fuel pump problem
    It could be a burned out resistor. Typically they allow the car to start then die.
    http://www.grandprixforums.net/fixin...lem-26549.html
  2. #2 Re: 97 gtp fuel pump problem
    nixa missouri
    Ok update. I bent pin 85 and now have fuel. So do I need to. Replace the resistor if so where is it or will this fix the problem
  3. #3 Re: 97 gtp fuel pump problem
    nixa missouri
    I called oreilys auto parts and a GM dealer and both say there is no resistor for gtps. Where can I get one at?
  4. #4 Re: 97 gtp fuel pump problem
    A 97 GTP has a resistor. It's located behind the washer bottle under the passenger side fender. Nearly impossible to get to. The fix that GM puts in is typically bolted to the center of the firewall near the top.
    Or you should be able to run in full speed mode w/o an issue. Might toss the tune off a little, but retune and smile.
  5. #5 Re: 97 gtp fuel pump problem
    nixa missouri
    Ok I did the relay. Had pressure last night today I let off pressure to see if It would build up. Now I have no fuel or spark.
  1. Problem after taking out fuel pump.
    By GAFF in forum General Tech Discussion
    Last Post: 02-21-2011, 03:15 PM
  2. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  3. fuel pump ground problem?
    By roger41076 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2010, 02:00 PM
  4. Fuel Pump Problem
    By ericrluoma in forum General Tech Discussion
    Last Post: 04-13-2009, 01:19 PM
