Thread: So I'm at a standstill...
Results 1 to 20 of 34
  1. #1 So I'm at a standstill...
    SE Level Member mousemonster1232's Avatar
    Surprise, AZ
    Based on the page that is Safely Mod your car or whatever, I have done (or not done) the following:
    1. Flip Dogbone mounts - no
    2. Cold Air Induction - yes
    3. 180* Tstat - yes
    4. Spark Plugs - yes, I used NGK TR55s
    5. Spark Plug Wires - yes
    6. Exhaust - Headers (downpipe change, Ubend delete, Cutout installed) - yes
    7. Reptile (thanks again) PCM tune - yes
    8. Port TB - no
    9. Port S/C case - no
    10. Pulley drop - yes, 3.4"
    11. Rockers - no
    12. IC - no
    13. Cam - no (seems like a CRAPLOAD of work)
    Let me know what you think I need to do next.
    Thanks.
  2. #2 Re: So I'm at a standstill...
    Cam or rockers. FWIW cam is very worth the effort.
  3. #3 Re: So I'm at a standstill...
    Feb 2008
    I'm with Bill on advice. A cam makes a world of difference. The total parts cost is barely more than rockers and the power potential is much greater. A cam swap is not as difficult as it may seem. There are a few how-to's on doing them floating around that will show you exactly what you need to do.
    I also recommend getting (or doing it yourself) a ported blower case. It will make the outlet temps a bit cooler.
    Might as well go ahead and flip the dogbone mounts. It's easy,free, and doesn't take long to do. Just make sure you use some WD-40 to lube the rubber before you try and flip it or else you might tear the mount.
    Not sure what year your car is, but if it's a '97 or '98, I've got a ported TB that will work well with a stock or ported supercharger.
  4. #4 Re: So I'm at a standstill...
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Just curious, what happened with your cylinder #4 misfiring?
  5. #5 Re: So I'm at a standstill...
    Kansas
    Id go with a cam, or save your money.
    SOLD 1999 GT Silvermist TS
  6. #6 Re: So I'm at a standstill...
    Surprise, AZ
    Bill and Dan, the only reason I think a cam is so much work is because just putting in the damned headers I broke $150 worth of stuff because they didn't go in, so trying to take them out again will be a nightmare.
    And my dogbone mounts are close to being rotted so I'm not sure if I want to mess with sasquatch and have them tear trying to twist them.
    My car is a '99.
    mechguy, I'm not sure. I checked both the plug and wire and they are both working fine. I haven't done the compression test as it is working as well as it did the day I got it. I'm not that worried.
    Also, I'm unsure if I should keep dumping money into the GTP or if I should take my dad's 351 he has in the garage he just offered me and go out and get a Ford to put it in... Oh the options... Everything on a 351 is a dime a dozen and so much cheaper, what to do what to do!
  7. #7 Re: So I'm at a standstill...
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    Concidence....I have a missfire on #4 also but everytime I pull the plug its kinda sticky so I think I have a bad valve stem seal. But dangtp, can you pm info on that throttle body of yours
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  8. #8 Re: So I'm at a standstill...
    Surprise, AZ
    Where in SE AZ are you, taman? I'm in the west valley...
  9. #9 Re: So I'm at a standstill...
    Nov 2010
    south east AZ
    im in safford, about an hour south of globe
    01 T/A WS6-SOLD
  10. #10 Re: So I'm at a standstill...
    What headers did you try to put in and how did you break 150 worth of stuff doing it?
    If you did that much with headers, maybe working on the GP isn't for you. I know a guy who does amazing work in the Phoenix area and he coudl surely help you out/straighten things up.
  11. #11 Re: So I'm at a standstill...
    Surprise, AZ
    I didn't try, I succeeded in the end, but they were Speed Daddy. Haha.
    And technically it wasn't me that broke the stuff, it was my dad. He just took a hammer and started smashing it because we couldn't get it going. Broke the bracket on the top back and everything on it like the EVAP sensor thing, Map sensor, and one other thing.
    Who is this guy and what kind of work does he do? What could he help me with, and are GPs specialty?
  12. #12 Re: So I'm at a standstill...
    Surprise, AZ
    Wow, taman that is quite a trek. haha. I live in Surprise, like I10 & 303.
  13. #13 Re: So I'm at a standstill...
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    with the high price of gas id prob keep the gp lol
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  14. #14 Re: So I'm at a standstill...
    Nov 2010
    south east AZ
    sh!t, here its 3.65 for permium, costs me 50 bucks to fill it up. my gf's car, scion xa, takes 30 bucks and can drive farther. i drive my car 10 min to and from work and thats it.
    01 T/A WS6-SOLD
  15. #15 Re: So I'm at a standstill...
    Troy OH
    Quote Originally Posted by mousemonster1232 View Post
    i would have straight kicked him in the dick. and then made him pay for it.
  16. #16 Re: So I'm at a standstill...
    GT Level Member jakewet28's Avatar
    Cincinnati
    You could buy my motor and exhaust 3800 and it's yours for engine and catback
    VS Cam, SS Intercooler, Powerflow catback, SSAC headers, open cone, 180* tstat, 42.5lb injectors, 2.8 pulley, 3.29 gears, zzp pcm, all supporting mods
  17. #17 Re: So I'm at a standstill...
    now that a guy with a short fuse lol
  18. #18 Re: So I'm at a standstill...
    Nov 2010
    south east AZ
    mouse, it takes me about 3 hours to get to AJ, four to get on the other side of phoenix
    01 T/A WS6-SOLD
  19. #19 Re: So I'm at a standstill...
    Dec 2010
    Canada
    Quote Originally Posted by Poil336 View Post
    Cannot...stop.....laughing.
  20. #20 Re: So I'm at a standstill...
    Surprise, AZ
    Quote Originally Posted by nascartech View Post
    High price of gas doesn't help at all with my GTP. 16 MPG and close to $4 for premium.
    Quote Originally Posted by taman86 View Post
    Yup, yup. It is ridiculous. -_-
    Haha. He did pay for it.
