Thread: "Perfect Shift" Indicator wont illuminate
Results 1 to 18 of 18
  1. #1 "Perfect Shift" Indicator wont illuminate
    El Cajon
    Let me say first that I tried it in both position push button in and out. And the indicator still wont Illuminate. Could it be a cable disconnected or loose. It was working about a week ago but now it's not. Any suggestion would be greatly appreciated. Could it be something simple like a bad bulb.
  2. #2 Re: "Perfect Shift" Indicator wont illuminate
    Prefect shift? or performance shift.
  3. #3 Re: "Perfect Shift" Indicator wont illuminate
    Dec 2008
    Lawndale, CA
    The bulb is probably out.
  4. #4 Re: "Perfect Shift" Indicator wont illuminate
    Kansas
    Any other bulbs out?
    Also check connections.
    SOLD 1999 GT Silvermist TS
  5. #5 Re: "Perfect Shift" Indicator wont illuminate
    Hi, welcome to the intro section were we would like to know a little about you and your car.
    When you are ready to post about a problem you are having, please ensure you put in the year and model of your car so that we can give you the best information and diagnosis.
  6. #6 Re: "Perfect Shift" Indicator wont illuminate
    El Cajon
    Sorry I have a 1998 Pontiac Grand Prix GTP and the problem is my "Perfect Shift" light wont illuminate. I believe the Perfect Shift is when the button on the shift lever is depressed. It is in Perfomance Shift Mode when the button is released it might be reversed. I cant tell my wont illuminate at all. The guy I purchased the car from did do some Mods to the car. Carbon Fiber Hood, Headers, and the vehicle was was lowered and Performance Struts installed. And now I cant contact him to ask if he disconnected the button.
  7. #7 Re: "Perfect Shift" Indicator wont illuminate
    No worries..you don't have a Perfect Shift button or light. Problem solved.
    Actually it's the performance shift. I'd pop the console lid and check for ground on one side of the connector. If that exists short the two wires together and see if the light kicks on. Most likley it's a switch or bad wire. Changing the bulb would require pulling the cluster, which is also not too bad.
    But since there's almost no difference in the two modes, it's doubtful you can feel the difference and are positive the bulb is burned out.
  8. #8 Re: "Perfect Shift" Indicator wont illuminate
    i've got a 98 regal but im sure its the same button on the shifter, so my button stays in when the perf button/light is on, and sticks out a bit more when off.
    i was stuck driving with out a cluster for a month and my knee hits the side of the sifter, so i looked real close to if it was on or off., and i can tell when it in performance mode or not just by how it shifts.
  9. #9 Re: "Perfect Shift" Indicator wont illuminate
    Sep 2011
    Oley Pennsylvania
    i have 98 gtp to an i have the same problem, the light worked fine for performance shift mode then it just died, im going to check the wiring to the bulb
  10. #10 Re: "Perfect Shift" Indicator wont illuminate
    Also check that the button is providing continuity to the pcm for ground.
  11. #11 Re: "Perfect Shift" Indicator wont illuminate
    Bunnell, FL
    are they talking about the dash light?
    cause the dic should work
    I'm a Sex Offender
  12. #12 Re: "Perfect Shift" Indicator wont illuminate
    you guys and your perf shift.......
    Snorlax strikes again.
  13. #13 Re: "Perfect Shift" Indicator wont illuminate
    I have a light in the dash and on the dic is that normal?
  14. #14 Re: "Perfect Shift" Indicator wont illuminate
    Bunnell, FL
    the two gtp's i have had never had the dash one
    but popping open the cluster is easy peasy to change a 192
    but i always go off the dic
    I'm a Sex Offender
  15. #15 Re: "Perfect Shift" Indicator wont illuminate
    Florida
    my 96 doesnt have a perf shift... but now with the 3800 swap, i guess i will run the wire and finally have it!!!
  16. #16 Re: "Perfect Shift" Indicator wont illuminate
    Worthless Troll
    LOL @ ''perfect shift''. I've had a few different people see that light on in my GTP's and think it stood for perfect and not performance.
  17. #17 Re: "Perfect Shift" Indicator wont illuminate
    Florida
    with tuning... it very well can be a perfect shift button. all depends on your deff of perfect! tire screeching or grandma shift
  18. #18 Re: "Perfect Shift" Indicator wont illuminate
    My GTP doesn't have performance shift.... the lights are there but no button... I don't need it anyway though...
  1. Hardware store "Shift Kit"
    By MBruneaux in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-29-2010, 06:55 PM
  2. no power car wont start dash light barely illuminate need help!!
    By mkedwards in forum Audio, Security & Visual Electronics
    Last Post: 03-19-2010, 07:44 PM
  3. Feedback/Opinions on the Intense "Shift Kit"?
    By Going Too Phast in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-30-2008, 10:10 PM
