No worries..you don't have a Perfect Shift button or light. Problem solved.
Actually it's the performance shift. I'd pop the console lid and check for ground on one side of the connector. If that exists short the two wires together and see if the light kicks on. Most likley it's a switch or bad wire. Changing the bulb would require pulling the cluster, which is also not too bad.
But since there's almost no difference in the two modes, it's doubtful you can feel the difference and are positive the bulb is burned out.
