Thread: o2-cat code question.
Results 1 to 6 of 6
  1. #1 Re: o2-cat code question.
    Donating Users
    South Deerfield, MA
    P0420 is a code that that computer throws when it determines the catalytic converter is not functioning properly. The computer reads the second O2 sensor and uses this reading to tell if the cat is doing it's job. Most of the time that will be a bad cat or an aftermarket cat that is not doing as good of a job as the factory one did. My car kicked a P0420 code after I put on the headers and high flow cat.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  2. #2 Re: o2-cat code question.
    Parker, Colorado
    So I am having this same problem, I am curious if I were to either delete the rear O2 by programming or purchase one of those plug-in O2 delete from ZZP would that take care of this problem alltogether?? I have an aftermarket cat, both new O2 sensors.
  3. #3 Re: o2-cat code question.
    Jul 2008
    sumter,south carolina
    In your case. U should be fine. Its more than likely the high flow cat that's throwing the code. It flows more than stock. So the computer sees diff readings. All u can do is get a stock oem cat or have that code set to non report via a tuner.
    02 GTP with mods 05 GP for DD
  1. TFP code
    By NightriderGT2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-21-2011, 05:53 AM
  2. code 1571 question
    By LAIDBACKLUKE in forum Brakes/Suspension/Chassis
    Last Post: 01-22-2011, 11:59 AM
  3. Have a question about this code
    By tyv193 in forum Off Topic Discussion
    Last Post: 08-09-2010, 11:08 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
