Thread: Clunk while turning steering wheel
Results 1 to 12 of 12
  1. #1 Clunk while turning steering wheel
    GT Level Member Z28's Avatar
    Oct 2008
    Omaha, NE
    1999 gp gt. 120k on it
    I did a quick search, but no one's description quite fit mine.
    If I am sitting in the driveway rotating the wheel about 60-90 degrees in either direction it makes a pretty loud clunk.
    Normal driving usually doesn't cause noise unless I go over a bump at low speed while turning sharply, it'll clunk pretty horribly if I do that. Even if I'm not turning and hit a large speed bump it'll make the same loud clunk. It's getting worse, it use to just do it on occasion, now it's very regular. Needs fixed.
    Another guy thought it might be the inner/outer tie rod ends...any ideas?
  2. #2 Re: Clunk while turning steering wheel
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Ball Joint
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  3. #3 Re: Clunk while turning steering wheel
    Oct 2008
    Omaha, NE
    Did you experience the same problem? How hard will it be to change? Can I do it? Is there any special tools used? Is there a how to?
  4. #4 Re: Clunk while turning steering wheel
    Mercer, Pa
    Look into intermediate shaft. I don't no the exact years it effects but I think it effects 99's. There is a lube kit from GM consisting of a plastic siring and rubber cork for $10 - $20 dollars. Take the intermediate shaft out and pull it apart(expand it), put the grease from siring down the tube. Cork the end and ca-lapse it, grease will shot out the splines. I recommend filling the tube completely with grease so that you don't have to do it again for a couple of years. Brand new ones have the same problem, but they have fresh grease.
  5. #5 Re: Clunk while turning steering wheel
    GT Level Member RamonGTX's Avatar
    menasha wisconsin
    Mine does that too and my axle boot is tore so I need a new one or what ever and all the grease is starting to be gone and it makes a clink noise when im stopped...
  6. #6 Re: Clunk while turning steering wheel
    St. Louis
    I had the same issue and it turned out that my front sway bar was cracked on both ends where the links go through it. Turn the wheels all the way to the right and take a look at the drivers side and you should be able to see the bar/endlink. Then do the same to the pass. side.
    I would turn and get a dull thunk everytime that piece gave a bit, especially when backing out of a parking space and turning the wheel. It looked to be getting stuck on itself, then popping free at some point.
    This is what I found on my drivers side...
  7. #7 Re: Clunk while turning steering wheel
    Pittsburgh
    It's not hard I did it on my 95 Monte, not my current car.
    Dremel off the factory rivets, have some kind of pry bar handy.
    Do both sides. At 120K you're due for ball joints anyways it wouldn't be terrible to replace them and not have it be the problem but clunks over bumps and turns usually is a bad ball joint. If you're gonna do anything else like tie rods do it all at once so you can get it aligned when you're done.
    Durkz 04 Silver GT2
  8. #8 Re: Clunk while turning steering wheel
    Oct 2008
    Omaha, NE
    Quote Originally Posted by FordMan77 View Post
    I can see that happening while driving, but mine will clunk when the vehicle isn't moving, just turning the wheel.
  9. #9 Re: Clunk while turning steering wheel
    Oct 2008
    Omaha, NE
    Quote Originally Posted by Durk Diggler View Post
    Thanks, I'll try and do that.
  10. #10 Re: Clunk while turning steering wheel
    Oct 2008
    Omaha, NE
    Well I think I'm gonna start with the ball joints, drive it, then try the tie rods, drive it, then the intermediate shaft i guess it's called. I have no idea what i'll be doing there, but I think I found a how to on that.
    I'll check for some loose bolts as well and see what I come up with, just gotta find some free time.
  11. #11 Re: Clunk while turning steering wheel
    HUDSON
    Check the rack and pinion mount bolts. I had to tighten mine becuse of a noise exactly like you described.
  12. #12 Re: Clunk while turning steering wheel
    Oct 2008
    Omaha, NE
    This describes my problem to a T, so I think I'll try the lube first.
    Thanks everyone
    http://ww2.justanswer.com/uploads/PE...602_impala.pdf
  1. Clicking noise when turning wheel
    By afallucco in forum Brakes/Suspension/Chassis
    Last Post: 10-13-2013, 10:16 PM
  2. clunk in steering wheel
    By fluffy54935 in forum General Tech Discussion
    Last Post: 11-12-2010, 03:58 PM
  3. Steering Clunk and Wheel Sudder
    By kissmyss in forum General Tech Discussion
    Last Post: 04-28-2010, 03:23 PM
  4. Rattling felt (and heard) in steering when turning and going over bumps
    By michgym170 in forum Brakes/Suspension/Chassis
    Last Post: 10-07-2009, 10:41 AM
  5. Turning/Steering Noise
    By chisels1 in forum General Tech Discussion
    Last Post: 06-17-2009, 06:38 AM
