Thread: Help wonderingnabout gaskets
Results 1 to 12 of 12
  1. #1 Help wonderingnabout gaskets
    Yoga city
    So I noticed a drop or two of oil on my garage floor today , so I checked my levels all about the same not sweet smelling or anything so I backed car out cleaned engine department and went for a drive it stuttered a lil bit but seemed fine it kinda smells like oil but no burnng or anything I. Just worried I bought this car yesterday no issues on my drive home it was an hour drive got on it a little bit no issues any ideas from the higher ups herr
  2. #2 Re: Help wonderingnabout gaskets
    Omaha, NE
    Its gonna be hard to give you advice if you can't tell where the oil is coming from. If you can, check where its dripping from, then let us know.
  3. #3 Re: Help wonderingnabout gaskets
    Yoga city
    Well it looks like it's around the steering rack but it's not steering fluid, alson on the front of the engine it has the normal grease on it from being a 97
  4. #4 Re: Help wonderingnabout gaskets
    Pennsylvania
    Quote Originally Posted by Jteske88 View Post
    it stuttered
    Something is broken.
    Also, I recommend grabbing a mirror and checking out your rear valve cover gasket.
  5. #5 Re: Help wonderingnabout gaskets
    Yoga city
    How long younthink I can drive like this I'm a granny haha imdont exactly think I can dish a ton of money out
  6. #6 Re: Help wonderingnabout gaskets
    Pennsylvania
    Broken things make more things break. Fix your st-st-st-stutter.
  7. #7 Re: Help wonderingnabout gaskets
    Akron Ohio
    Fix it before more things break.
  8. #8 Re: Help wonderingnabout gaskets
    bought it yesterday, you see an issue..
    Easiest way to ID and fix an oil leak issue.
    Clean the engine and drive. Then look/feel for leaks each morning or evening (just don't burn your hands).
    By cleaning it, you can differentiate which leak is new and which was just residual dirt from years of not being clean.
  9. #9 Re: Help wonderingnabout gaskets
    Yoga city
    So I had a couple days go buy with two smalls drops of oil on my garage floor but can't see exactly or find were there coming from
  10. #10 Re: Help wonderingnabout gaskets
    Pennsylvania
    Shoot, man, if you can't see, then we sure as heck can't.
  11. #11 Re: Help wonderingnabout gaskets
    Please reread my message earlier about cleaning and inspecting. We can't really work miracles from many miles away. You are going to have to be our eyes and hands. With you taking pics and telling us what you see, then we can help by suggesting the usual leak areas and help you through the fixes.
    If ya don't do that stuff, then we'll be forced to joke around and be jerks because there's nothing else we can do w/o you helping fix the issue.
  12. #12 Re: Help wonderingnabout gaskets
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    These cars leak oil from the factory. I wouldn't necessarily be too concerned about that depending on where it's coming from. As mentioned earlier, get some degreaser and clean it all off and you should be able to easily spot where the leak is coming from. Oil pan leaks are common and that would be my first guess.
    The studder is most likely ignition/ fuel related but again, typically not a big deal. Could be either bad plugs, old wires, a dirty MAF or any other number of sensors not reading properly. Generally the first place to look is the plugs and wires. Your average owner doesn't generally see these as something that needs replacing and so a LOT of cars are running around on their original wires... Scary. :-)
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  1. Where to buy gaskets?
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-23-2010, 02:50 PM
  2. LIM gaskets
    By jmac in forum General Tech Discussion
    Last Post: 12-01-2009, 07:38 PM
  3. What are all these gaskets?
    By piperflyer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-07-2009, 02:22 AM
  4. What do you use? (gaskets)
    By TDCRacing in forum Off Topic Discussion
    Last Post: 01-27-2009, 04:07 PM
