Thread: What are all these gaskets?
Results 1 to 5 of 5
  1. #1 What are all these gaskets?
    Apr 2009
    Ohio
    Ok, I need a little help identifying these gaskets and knowing where they go. I bought a FelPro gasket set. I had a valve job done on the heads so I have to use the entire set, I assume. Can someone help me out with each of these gaskets? I assume the black o rings are for the fuel injectors.
    What are all these gaskets? Attached Images
  2. #2 Re: What are all these gaskets?
    Injectors O-Rings are the small black circled ones...
    Valve Cover Grommets are the blue ones...
    Big orange one is the TB gasket
    the rectangular gasket goes on the LIM under the throttle body...and the orange rings in the same bag should be the coolant passage o-rings IIRC...
    Those other ones...probably some L36 crap I can't remember. I haven't worked on a L36 UIM/LIM since 2006 when I did a UIM swap for my Mom on her LeSabre...first 3800 I ever worked on
  3. #3 Re: What are all these gaskets?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    The black one looks likes its for the thermostat
  4. #4 Re: What are all these gaskets?
    Apr 2009
    Ohio
    The injector o rings and valve cover grommets make sense. The other ones I'm not sure if I took them off originally.
  5. #5 Re: What are all these gaskets?
    You might not have...so just save them
  1. intake gaskets
    By dpmeeks in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2009, 01:24 PM
  2. Are L36 and L67 head gaskets the same?
    By TDCRacing in forum General Tech Discussion
    Last Post: 03-12-2009, 01:09 AM
  3. What do you use? (gaskets)
    By TDCRacing in forum Off Topic Discussion
    Last Post: 01-27-2009, 04:07 PM
  4. Gaskets
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2008, 11:17 AM
  5. Head Gaskets...
    By newfie in forum Turbo
    Last Post: 01-18-2008, 12:31 AM
