Thread: Can the mielage computer be adjusted?
Results 1 to 15 of 15
  1. #1 Re: Can the mielage computer be adjusted?
    Pennsylvania
    I'll just pull this out of my ass:
    You'll need to reprogram (with a tuner) whatever it is that reads the wheel speed sensor if you are running wheels/tires that do not equal stock diameter or the diameter has changed since you last tuned it.
    The rest is sensed by your fuel pump's floaty doodad (so that's not wrong) and your O2 sensor... which isn't wrong, either, unless you broke it.
  2. #2 Re: Can the mielage computer be adjusted?
    Apple Valley, MN
    Quote Originally Posted by SlowNA06 View Post
    Tires are stock sizes... I wouldn't think the fuel pump floatie calculated how hard you were pressing on the gas.
    o2 sensor is windeband but read by the ECU correctly.
    ‎1998 GTP. ZZP intercooler, 3.1 quickchange Pully, ZZP 8 rib, ZZP Fuel Rails, 42 lb/hr injectors, Thrasher cold air intake, High flow Cat, U-bend delete, Fuel pump hotwire kit, Custom ECU Tune, 180 Tstat, Intake Port-Matched to SC, DynoJet wideband commander, 12" FBody Brakes. 2.8" pully & tunes for 3.1"/E85, and 2.8"/E85
  3. #3 Re: Can the mielage computer be adjusted?
    Pennsylvania
    Quote Originally Posted by zeeboid View Post
    Nope. It's what tells the gauge how much gas is in the tank. You're looking for throttle position sensor, if I'm not mistaken.
    I'm too stupid to know what you're trying to tell me here. Could you rephrase that, please?
    Hmm, by "hardware," do you mean "injectors?" I don't think that or E85 is going to affect your readings.
  1. computer help
    By gtpinsc in forum Off Topic Discussion
    Last Post: 05-22-2010, 01:50 PM
  2. CAI and the computer
    By BigTom73 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 07:57 PM
  3. computer help
    Last Post: 10-21-2009, 09:49 PM
  4. Trip computer
    By SCGTP in forum Audio, Security & Visual Electronics
    Last Post: 07-09-2009, 06:52 PM
  5. Need Computer Help
    Last Post: 04-06-2008, 11:58 PM
