Those aren't codes. You are giving us general sensor names.
If you ask me what all those items have in common, it's the grounds at the front lower bolt of the transmission. Should be the neg battery cable, and two black wires hooked up there. I'd take them off, ensure they are clean and in good overall shape. You have nearly every sensor on the engine tossing a code... that's typically something else causing the issue. Ground/Power and the PCM are the three things in common with all those sensors. I'd start at the grounds like mentioned.
