Thread: Cat-less make a big diff?
Results 1 to 14 of 14
  1. #1 Cat-less make a big diff?
    SE Level Member mousemonster1232's Avatar
    Surprise, AZ
    I was thinking about making another downpipe, or finding someone with the ability to that does not have a cat in it.
    Is there a real advantage to doing so? Would it really change anything other than the sound?
    For example one for street and one for racing.
    Thanks.
  2. #2 Re: Cat-less make a big diff?
    SE Level Member glhtomni's Avatar
    iowa
    not sure on actual statistics, but cats are very restrictive, even when new and not clogged at all, so by rights removing it has to add flow and flow usually increases power and performance.
  3. #3 Re: Cat-less make a big diff?
    wrong. cats are not very restrictive.
    the only reason to not have a cat is to not have to worry about it clogging. other than that, doesnt do anything for performance or sound.
  4. #4 Re: Cat-less make a big diff?
    it doesnt do anything for performance or sound.
    First one...I agree.
    Second...however...no. Going from a stock downpipe to a catless one makes a noticeable sound difference...and even more so when running headers. All of those setups were through a stock catback and you know how quiet a stock catback can be...it was quite a sound difference to know it wasn't stock.
  5. #5 Re: Cat-less make a big diff?
    Surprise, AZ
    So it wouldn't really do much for me to interchange them for racing/street, correct?
  6. #6 Re: Cat-less make a big diff?
  7. #7 Re: Cat-less make a big diff?
    iowa
    I find that funny actually, guess in a n a car that could be true. But in a blower or turbo car, removing the cat and muffler increases flow and horse power. I own a 16 valve car turbo, intercooled, with a ful 3" mandrel bent exhaust, no cat or muffler. I went from low 14s to 13.7 on low boost, plus all the cool kids going 7s to 12s are doing it.
  8. #8 Re: Cat-less make a big diff?
    iowa
    For the poor guys with emissions testing they sell hollowed cheater cats, so you cam pass a visual inspection and I guess the hollowed part must be for weight shaving since flow is useless right?
  9. #9 Re: Cat-less make a big diff?
    Jersey
    what?
    turbo car yes
    i don't run a cat simply because i don't feel like buying one
    16' wrx sti- stock
  10. #10 Re: Cat-less make a big diff?
    our cars dont run enough boost for a cat to be a restriction unless you run a turbo setup.
  11. #11 Re: Cat-less make a big diff?
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Not to mention back pressure measurments on the Cats themselves are very minimal. If you clog yours and dont have emissions testing you can run without it to save the cash of getting a new one... But that just smells bad for everyone get a high flow cat in that case if your worried. You will convert enough to pass federal aftermarket requirements and not have to be concerned with back pressure measurements (as bio stated you dont anyways)
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  12. #12 Re: Cat-less make a big diff?
    Ocala, FL
    If I'm not mistaken its somewhere around 350, maybe 400whp before the stock cat becomes restrictive.
  13. #13 Re: Cat-less make a big diff?
    Stock cat...I'd never run one just because I like to have it ruled out already so it isn't problematic. The catback however doesn't become restrictive until about 350 FWHP...yes.
  14. #14 Re: Cat-less make a big diff?
    Donating Users 98GTPstat's Avatar
    Dec 2010
    livonia, Mi
    alll that i can think of is how many miles is on ur cat. if it issemi cloged yes you will notice a slight difference in sound and accleration. but nothing more then if you bought it off the show room with 0 miles on the cat. now like kody was saying they do become restrictive over 400 hp give or take around 50 hp
  1. HD Diff???
    By 05grndprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-31-2008, 08:26 AM
  2. Diff between S/C L32 and an S/C L67
    By Keet04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2008, 06:50 PM
  3. Torsen Diff
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-25-2008, 10:10 AM
  4. Tranny whine after diff and diff case replace...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2008, 09:27 PM
