Thread: EGR Valve Stuck?
Results 1 to 13 of 13
  1. #1 EGR Valve Stuck?
    Nov 2010
    Buffalo Ny
    Hi, I have a 2006 Pontiac Grand Prix 3.8 liter. A couple weeks ago my check engine light came on reading code P0411 (secondary air intake) so I replaced the air pump. I reset the code and the light came back on. I have finally to it to a shop and they hooked it up to a computer and it is saying the egr valve is stuck. so they replaced that and the relay. the code was off for a couple days now its back on? I took it there today and it is still saying it is stuck they have checked all the wiring thinking it was a short but cant find anything? just wondewring if anyone know what it could be? i was just reading about DPFE sensors does the grand prix have one? Please help thank you
    Mike
  2. #2 Re: EGR Valve Stuck?
    SE Level Member chuckd98gtp's Avatar
    Apr 2009
    Long Beach
    Sounds like you got the same problem as me... I'm taking it off today to clean it up real good. but it's only like a year old. so... I don't really know. but ill let you know if i find anything. side note, it seems like i only throw the code when im under prolonged boost, on the freeway or going up a hill ya know.
  3. #3 Re: EGR Valve Stuck?
    Jul 2008
    sumter,south carolina
    take it off... get some carb cleaner.. spray carb cleaner into hole on bottom.. work the plunger with a coathanger or whatever.. repeat process a few times if needed.. when its clean the plunger should work freely.
    02 GTP with mods 05 GP for DD
  4. #4 Re: EGR Valve Stuck?
    Donating Users mystic231's Avatar
    Michigan
    Or unhook it and get an Overkill PCM.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  5. #5 Re: EGR Valve Stuck?
    Apr 2009
    Long Beach
    so i soaked it in carb cleaner for like an hour and worked the plunger like gtpinsc suggested. I also cleaned out the gas cap real good and threw some white lithium grease on the gasket on the gas cap. ses has been off since, drove like 200 miles since sat... ill keep you posted
  6. #6 Re: EGR Valve Stuck?
    Apr 2009
    Long Beach
    ses came on again on friday approx 1000 miles later, idno guys open to suggestions
  7. #7 Re: EGR Valve Stuck?
    Jul 2008
    Buy another one. Or just get rid of it all together by doing a egr delete.
  8. #8 Re: EGR Valve Stuck?
    SE Level Member ejechtion54's Avatar
    Ft. Wainwright
    So if I did an EGR delete can I just take the EGR valve off and flash the PCM and everything is good?
  9. #9 Re: EGR Valve Stuck?
    Joliet, IL
    Yep delete that *****.....gotta use block off plates though make some or go on zzperformance.com and get em....need to clear the code off the pcm as well so the car can pass emissions. I currently have no cats, egr, or evap and still passed emissions.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  10. #10 Re: EGR Valve Stuck?
    Ft. Wainwright
    Quote Originally Posted by BoostJunki3 View Post
    Right now I am stationed up the oh so wonderful state of Alaska and in the region I am in there is no emissions test :P. I will look into zzperformance.com. About not having a cat/resonator/or muffler will it burn up the valves, since GM cars need back pressure to start? (Which is gay)
  11. #11 Re: EGR Valve Stuck?
    Jul 2008
    Someone gave u false info on the whole back pressure thing. U can use the egr brackets and RTV coins on them to block the holes. I've been running mine like that for over 2 years now with no issues.
  12. #12 Re: EGR Valve Stuck?
    Ft. Wainwright
    Yeah I looked it up last night. I found a few articles and on the trashed performance site they have an in-depth article all about it.
    Who ever said "Out with the old and in with the new."?
  13. #13 Re: EGR Valve Stuck?
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    I wanna know how you reset the codes in your computer? just press enter on the DIC???
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  1. 04+ HUD is stuck...
    By PonchoDvr4Lfe in forum General Tech Discussion
    Last Post: 02-22-2012, 01:55 PM
  2. o2 is stuck
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2010, 06:48 PM
  3. oh its stuck
    By ChdMcD in forum General Tech Discussion
    Last Post: 04-17-2010, 06:50 AM
  4. what im stuck with
    Last Post: 07-20-2009, 05:31 PM
  5. How Come My Car Gets Stuck In This Vid.....
    Last Post: 12-17-2008, 02:18 AM
