Thread: 2004 squeal coming from under the hood
Results 1 to 5 of 5
  1. #1 2004 squeal coming from under the hood
    Aug 2011
    Flint
    I reciantly changed the valve covers on my 2004 gtp comp g and I started it and the elbows broke in my water pump and coolant went every were now it's squeealing like crazy I put belt dressing on my belts it stopes for a sec then 45 mins later or 20 it started again can u guys help me
  2. #2 Re: 2004 squeal coming from under the hood
    St. Louis
    Yes, clean all the pulleys off w/ brake clean after removing the belt to allow you to turn them to be sure you got all the grooves clean and replace the belt. The belt is probably saturated w/ coolant now and will most likely never stop squealing.
    You can try washing the belt off but not sure how well that will work.
  3. #3 Re: 2004 squeal coming from under the hood
    Aug 2011
    Flint
    Thanks any one know of a cheap place to re manufacture my H.U.D
  4. #4 Re: 2004 squeal coming from under the hood
    Belts are cheap you can replace them if you want, but I had this happen with my alternator so I replaced it with a used one for $50 off ebay. So if could be one of the pulleys, if you can listen and get a general idea of the area its coming from then you can usually replace the culprit...its probably a Tensioner pulley
    You can get a used HUD usually off Ebay from Ed Morad
  5. #5 Re: 2004 squeal coming from under the hood
    On the HUD. there is a typical spring or clip that breaks and makes it shine off in left field. I believe we have a post of how to fix your year hud here. Give it a search. If you don't find it.. please post again and I'll get you a write up.
  1. belt squeal
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2011, 03:10 PM
  2. 2004 Grand Prix Limited Edition GTP Comp G hood scoop/vents?
    By schlue in forum General Tech Discussion
    Last Post: 01-02-2011, 11:19 AM
  3. Random Squeal
    By zagzagel in forum Introductions/Noob Questions
    Last Post: 09-03-2010, 07:23 PM
  4. Clicking coming from front end 2004 Grand Prix
    By bjornbjorn in forum General Tech Discussion
    Last Post: 08-02-2010, 05:53 PM
  5. squeal
    By dbean in forum Brakes/Suspension/Chassis
    Last Post: 10-18-2008, 04:22 PM
