Thread: Burnt out light in shifter box
Results 1 to 10 of 10
  1. #1 Burnt out light in shifter box
    SE Level Member pghtattooer's Avatar
    pittsburgh,pa
    Does anyone know how to replace the light inside the shift box.?
  2. #2 Re: Burnt out light in shifter box
    Apr 2009
    Wausau, Wisconsin
    If you are talking about the lights in the center console to the left of the shifter, you pop off the top of the center console and its just a bulb
  3. #3 Re: Burnt out light in shifter box
    pittsburgh,pa
    So the whole center console has to be removed to get to the bulb?
  4. #4 Re: Burnt out light in shifter box
    GT Level Member dengnath's Avatar
    if it is a 04+ yes the whole console must be removed with the 4 screw by the floor.... and that is the reason mine will not be done.... because i had to remove it to put in my carbon fiber trim and it was a PITA... so it will remain burnt out
  5. #5 Re: Burnt out light in shifter box
    pittsburgh,pa
    Crap...o well ill remove it coz its bugging the hell out of me lol
  6. #6 Re: Burnt out light in shifter box
    its not as bad as i described i guess... it just sucks cuz it is push the seat back take out the screw then push the seat forward take out the screw, then push the other seat back, then forward, and it just sucks, you will also probably have to pull off the radio trim and the empty din box at the bottom to make like easier. every other damn plastic part on the car has clips and that is the only darn piece of trim with screws.
  7. #7 Re: Burnt out light in shifter box
    Apr 2009
    Wausau, Wisconsin
    I would recommend looking at LED replacement bulbs so you don't have to deal with it again..
  8. #8 Re: Burnt out light in shifter box
    pittsburgh,pa
    Sweet thanks guys.
    Also does anyone know if im able to drop my car and still be able to fit 20s I have an 06.
  9. #9 Re: Burnt out light in shifter box
    Apr 2009
    Wausau, Wisconsin
    Check the wheel and tire section, Bio has a good thread there and if its not covered then do a search then if you still cant find anything ask in the chat when bio or drunkie is around.
  10. #10 Re: Burnt out light in shifter box
    pittsburgh,pa
    Thanks
  1. Shifter Console Light Bulb Replacement
    By packerfanjc in forum General Tech Discussion
    Last Post: 02-16-2011, 12:34 AM
  2. DIC llight burnt out
    By 2000GrandPrixGT2000 in forum Audio, Security & Visual Electronics
    Last Post: 11-09-2010, 11:49 AM
  3. burnt red!
    By SlowM90 in forum Off Topic Discussion
    Last Post: 02-11-2010, 06:29 PM
  4. Shifter does not light up
    By Jesse in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2009, 10:23 PM
  5. 2004 GP GT Shifter light is out
    By KYboondockSaint in forum General Tech Discussion
    Last Post: 07-29-2009, 09:45 PM
