Thread: DIC llight burnt out
Results 1 to 9 of 9
  1. #1 DIC llight burnt out
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    Alright well my DIC backlight is in the process of burning out
    It seems to only be the left red light and not the right
    Does anyone know of where to get a new bulb to replace them?
    Also how would I go about changing them?
  2. #2 Re: DIC llight burnt out
    GTP Level Member SuperSport's Avatar
    Michigan
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: DIC llight burnt out
    Ocala, FL
    For some reason that link isn't working.
  4. #4 Re: DIC llight burnt out
    SE Level Member techweenie's Avatar
    Nov 2009
    Grand Blanc, MI
    I got the bulbs from NAPA. They were the only auto parts store I could find that sells them. They are pretty easy to replace. Just pull the dash trim off and the DIC slides out with the bulbs accessible on the back.
  5. #5 Re: DIC llight burnt out
    Never Never Land
    Quote Originally Posted by techweenie View Post
    Are they plug in or soldered on? My left one works intermittently...could just be a loose connection though. Sometimes if I kinda tap it the light will come back on so i think it's just the connection.
  6. #6 Re: DIC llight burnt out
    Ocala, FL
    If you can tap it and have it on, its 100% guaranteed the bulb isn't burnt out, definitely a connection.
  7. #7 Re: DIC llight burnt out
    Never Never Land
    Quote Originally Posted by codyAK View Post
    I'm confused though because the whole DIC goes out completely or just the right side lights up. It's done that ever since I put my HUD in. I messed with the connector makin sure none of the wires were pinched or anything but I can't figure it out.
    My brother's car does the same thing when we put HUD in his. Except his either works or it doesn't. It's not like mine where only half of it works.
  8. #8 Re: DIC llight burnt out
    Nov 2009
    Grand Blanc, MI
    Sounds like a loose connection or faulty wire splice somewhere. You could always run the wire for the lights directly to a switched power source, but you'd lose the dimming feature.
  9. #9 Re: DIC llight burnt out
    Never Never Land
    I didn't have to splice though...my car is a 97 so it had the pigtails in there.
  1. compound burnt onto roof
    By coombsctgtp in forum Detailing Tips and Tricks
    Last Post: 10-15-2010, 06:06 PM
  2. Plugs burnt/bent and 27* knock!
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2010, 12:12 PM
  3. burnt red!
    By SlowM90 in forum Off Topic Discussion
    Last Post: 02-11-2010, 06:29 PM
  4. My radio hates my Burnt cds
    By reffer101 in forum Audio, Security & Visual Electronics
    Last Post: 12-11-2009, 11:50 AM
  5. Transmision fluid burnt. Do i flush it?
    By joshb227 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 09:13 PM
