Thread: Problem after taking out fuel pump.
Results 1 to 4 of 4
  1. #1 Problem after taking out fuel pump.
    Kansas
    My car needed a new fuel level sensor. I replaced it and put the pump back in.. Had troubles removing the hoses.
    I think I might have not connected one of the hose right due to a clip not holding.
    Now tomorrow im tearing it back open but here is my question.. My LTFTs are all over the place now is that cause of the leak. I filled up the tank and it started pouring out.. But then after a point it stopped and I drove it home. I see as low as -22 ltfts and high as 16 ltfts.
    Does a leak cause the ltfts to be like that?
    SOLD 1999 GT Silvermist TS
  2. #2 Re: Problem after taking out fuel pump.
    Kinda vague in your description, but it sounds like the o-ring that seals the pump to the tank isn't sealing properly. That could cause a few issues.....
  3. #3 Re: Problem after taking out fuel pump.
    Jul 2008
    sumter,south carolina
    X2 on o ring.. its prob not seated right..or fell in tank on re install... mine rotted out on my old gt and would pour out gas on fill ups or taking a sharp curve.
    02 GTP with mods 05 GP for DD
  4. #4 Re: Problem after taking out fuel pump.
    Kansas
    I think tomorrow im going to tear it all open and pull the pump out and make sure the seal is all good.. problem is a have almost a full tank.. will that be ok?
  1. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  2. fuel pump ground problem?
    By roger41076 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2010, 02:00 PM
  3. Fuel Pump Problem
    By ericrluoma in forum General Tech Discussion
    Last Post: 04-13-2009, 01:19 PM
  4. Taking a few seconds to start? Starter the problem?
    By Z28 in forum General Tech Discussion
    Last Post: 03-27-2009, 11:09 AM
