Thread: How to get a dead battery out
Results 1 to 18 of 18
  1. #1 How to get a dead battery out
    Michigan
    Ok, here is a strange one. I work out of town weekly and since I have a rental for my job, I haven't driven my Grand Prix much. I started it every 3-4 weeks just to keep things running alright. Well, last month I went to start it and found that the battery had gone dead. I assume it is the winter weather in Michigan. I tried to open the door so I could get it out and charge it, but the key doesn't open the door. Apparently it is only for the ignition. Have I just gotten screwed by the dealership (I bought it used)? Is there another way to get the hood open so I can get the battery out?
    Thanks,
    Scott
  2. #2 Re: How to get a dead battery out
    Nov 2008
    Waterloo, Iowa
    What year is it? I know for a fact 97+ use the same key for the door and the ignition. If it's not working in one, then it's not a factory key, and is a bad cut...
    Best idea for now? Call a locksmith, have him pop the door open, don't lock it again until you have a new key.
    Also, you sure its the battery in the car, and not the one in the remote? If the car won't open you really wouldn't be able to tell...
    Edit: Yeah I think your key is a nasty cut, because if you have a remote, no way your car is going to have separate keys for the door and the ignition...
  3. #3 Re: How to get a dead battery out
    Charles City, IA
    Coat hanger and unlock the door, I can open a gp in under 2 min now.
    SMGPFC Two Nipple General
  4. #4 Re: How to get a dead battery out
    Michigan
    Its an '04 and I have 2 fobs and 2 keys that the dealership gave me. I'll get the other key from my ex and see if it works.
  5. #5 Re: How to get a dead battery out
    Charles City, IA
    Might have to call a lock smith and have them open it for ya.
  6. #6 Re: How to get a dead battery out
    Never Never Land
    Quote Originally Posted by TheOtherNick View Post
    my brother locked the keys in his 96...we took the antenna off and got in it that way lol
  7. #7 Re: How to get a dead battery out
    ^^That.
    Done that on a couple mustangs...
  8. #8 Re: How to get a dead battery out
    TN
    I have to say locksmith, but if money is a problem maybe you can go through the grill.
    88 fiero formula l67
    04 ninja
  9. #9 Re: How to get a dead battery out
    Omaha, NE
    Buy a Jimmy, they should be around $20 and most pawn shops seem to have em.
  10. #10 Re: How to get a dead battery out
    GT Level Member 05CompG's Avatar
    Arizona
    04+ uses one key for ignition and door. Urs was definently a bad cut.
    Her Name...Stacii Dash
  11. #11 Re: How to get a dead battery out
    Delaware, OH
    Nobody considering the fact that they might have replaced the ignition cylinder or door locks???? Seen that happen a couple times.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  12. #12 Re: How to get a dead battery out
    Nov 2008
    Waterloo, Iowa
    That too.
  13. #13 Re: How to get a dead battery out
    I'd try the other door
  14. #14 Re: How to get a dead battery out
    Michigan
    All good suggestions. Never thought of the locks being changed. The two keys I have are both GM keys, so they came from the dealership, but that doesn't mean there isnt something wrong with them.
    The easiest would be to get the 2nd key and see if that works (hope). I'll go from there.
    Thanks,
  15. #15 Re: How to get a dead battery out
    SE Level Member Gorecki's Avatar
    Nov 2010
    Maryland, US
    Yeah, as said already, door is the same key as the ignition on that year so my first guess is the ignition was changed and the doors weren't. That would totally suck to discover after the fact.
    [TRADED] 2005 Grand Prix Silver
    K&N Air Filter, NGK TR55GP G-Power Plugs, Delphi OE Wires, Timken Bearings, Mobil 1 Synth ATF & Oil, Purolator PureOne Filter
  16. #16 Re: How to get a dead battery out
    Michigan
    You can unlock with a slim jim unless they changed the lock stuff for the 04's. I used to work as a fabricator and in my 03 I somehow locked my keys in the car. The one guy has used these before and said we can easily make one. We used the metal straps that come on palettes and hold the sheet sheet down. Cut a 3 foot piece and on the one end make an angled notch in it. It sure worked and now I carry it with my and helped a few people get in their cars.
    I know the 97 to 03's dont have a blocker plate but not sure about the o4's. But you slip it down by the handle going towards the back and pull up. It took a few tries and I dont know what im hooking onto but it works. Kind of beats a hangar because you dont have to try pulling the door away and fishing it down. Or just buy one as one suggestion was already said.
  17. #17 Re: How to get a dead battery out
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    what about the trunk...try and open the trunk and crawl in that way..i did that once in a friends car...if that fails use a chainsaw and cut your way in
  18. #18 Re: How to get a dead battery out
    Michigan
    Thanks for the suggestions. My ex's key worked just fine.
  1. Battery going dead?
    By 90oddz in forum General Tech Discussion
    Last Post: 11-06-2010, 06:54 PM
  2. Battery Dead.. Perhaps from the AMP?
    By Supercharged03GTP in forum Audio, Security & Visual Electronics
    Last Post: 10-02-2009, 11:15 AM
  3. GTP is dead
    By JayGTP02 in forum The Rant Forum
    Last Post: 05-15-2009, 12:07 AM
  4. car = dead
    Last Post: 02-10-2009, 09:03 PM
  5. Dead!
    By GTPluv in forum Southwest
    Last Post: 02-26-2008, 01:04 AM
