Thread: Rear Valve Cover
Results 1 to 11 of 11
  1. #1 Rear Valve Cover
    SE Level Member Amb4's Avatar
    Nov 2009
    Canada
    How do i get it off!? im going crazy lol. I took everything around it off except that one big bracket that holds the Alt in place and has those 2 hoses attached to it. Do i really need that to come off because i'm almost positive last time it just slid out from under it or something. I don't remember having to take it off.
    It just looks like there's way to much attached to that one piece for it to have come off last time. I tried cranking the engine over so it would close the valves and make more clearance but it didn't help.
  2. #2 Re: Rear Valve Cover
    Charles City, IA
    I pull that bracket when I do them. I guess you can get it off with out doing it, put I just pull the bracket.
    SMGPFC Two Nipple General
  3. #3 Re: Rear Valve Cover
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Word around the forum is you need to loosen that bracket off and slide it forward some. Dont think it has to be taken completely off. How goes the battle so far, Valve Cover gaskets are in my not so distant future.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  4. #4 Re: Rear Valve Cover
    Nov 2009
    Canada
    hmm alright, well i tried taking the 2 most visible bolts out to see if that would loosen it but it didn't.. how many bolts are there in total that come out?
  5. #5 Re: Rear Valve Cover
    SE Level Member 02 35thLE's Avatar
    ankeny ia
    3 bolts hold the tensioner bracket on. Just be careful not move that much and break one of the plastic coolant elbows.
  6. #6 Re: Rear Valve Cover
    Buy a set of elbows and change them when you pull the bracket. $4 is worth not having a leak when you are done.
    The third bolt is out of sight. Reach your hand back on that bracket and feel where it continues past the heater hose a bit.
  7. #7 Re: Rear Valve Cover
    Nov 2009
    Canada
    ok thanks guys, i ended up finally getting it off!
    But then i got stuck on the rear header haha man was that a pain in the ass to wedge out of there.
  8. #8 Re: Rear Valve Cover
    You got what stuck on the header?
  9. #9 Re: Rear Valve Cover
    Nov 2009
    Canada
    no i was taking the header off of the car and the way the shape of it is just made it so hard to wedge out. It was a lot easier going in then coming out
  10. #10 Re: Rear Valve Cover
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    Quote Originally Posted by Amb4 View Post
    It usually is..
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  11. #11 Re: Rear Valve Cover
    Not if you lower the subframe slightly. It's easy both ways.
  1. Rear valve cover removal
    By Angleiron in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-02-2012, 11:58 AM
  2. Changing rear valve cover gasket
    By rudedude in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2009, 02:20 PM
  3. Rear Valve Cover Removal
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 08-24-2008, 12:46 PM
