Thread: Have 2 engine codes
Results 1 to 14 of 14
  1. #1 Have 2 engine codes
    Kansas
    P0141 - This code means that the heated circuit in the oxygen sensor on bank 1 decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0141.
    SO my questions is what do I do about that?
    P0507 - Which is too high of a idle.
    What do I do about that? I changed the TPS a couple times a while ago when I was having problems with my MAP.
    Think its a bad TPS? or should I look into the tune? I have a tuner.
    Help is appreciated.
    I googled both just would much rather see if other have experienced this in the past..
    SOLD 1999 GT Silvermist TS
  2. #2 Re: Have 2 engine codes
    Omaha, NE
    Is this on a stock tune?
  3. #3 Re: Have 2 engine codes
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    log TPS percent at idle, Should be able to figure out if thats the issue pretty quickly
    Heater circut usually is from a bad 02 sensor in my experiance. But it could also be a pinched/bad wire. What idle are you commanding?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Have 2 engine codes
    Kansas
    Not a stock tune at all considering I am a topswapped engine. The Idle settings in tune are all set to stock though.
    In recent logs I've looked at it shows up like a .34 idle percent every once in a while when not hitting the gas.. would it really cause a code like that.. Its never a constant .34 or whatever it was.
  5. #5 Re: Have 2 engine codes
    Hagerstown,Md
    Id pull the IAC valve and give it a bath and see what happens
  6. #6 Re: Have 2 engine codes
    Kansas
    so just take it off clean it up with????
  7. #7 Re: Have 2 engine codes
    Hagerstown,Md
    Carb cleaner, Gum cutter. What ever. Clean inside the bore as best you can, and all around the spring. They get pretty gunky
  8. #8 Re: Have 2 engine codes
    Kansas
    ok thank you.. Still what if that all fails and help with the sensor..
    The o2 is in the cross over pipe.. could that be causing something
  9. #9 Re: Have 2 engine codes
    Hagerstown,Md
    Nah I ran mine there aswell. I didnt have any issues. 02's heater code is usually the sensor failing itself.
    Id be surprised if cleaning the IAC doesnt do the trick.
  10. #10 Re: Have 2 engine codes
    Kansas
    Ok thanks man
  11. #11 Re: Have 2 engine codes
    If all that doesn't clear your high idle, remove the cruise cable from the TB, check idle..then remove the throttle cable. Does the issue go away with either cable?
    Mess with the loop de loop of throttle and cruise cables that GM put on the dumbuyah body strut tower. Been there..fixed that..lol
  12. #12 Re: Have 2 engine codes
    Kansas
    You know what? Honestly even though my car is throwing that code the idle isn't even that high so thats why I get confused but today after class im going to mess with it.
    I was trying to hook up my tuner and the damn box wouldn't even turn on to connect to my car.. no clue why as of now
  13. #13 Re: Have 2 engine codes
    Bastard Reptile's Avatar
    Kansas City, MO
    If the idle circuit is fluctuating, it could be a short somewhere in the wires too. The PCM knows when the throttle blade is closed even when the circuit has a spike in the voltage. Hence the code.
    Curtis had this problem, and it turned out that one of his TPS wires was rubbed through somewhere in the harness. Took almost 2 years to find.
  14. #14 Re: Have 2 engine codes
    Kansas
    shoot so better clean then start looking
  1. Engine codes
    By postalizer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-10-2010, 10:20 AM
  2. Help with SES codes, engine surging.
    By Fast68Camaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 06:20 AM
  3. SS intercooler and header install = engine codes
    By rascal in forum General Tech Discussion
    Last Post: 09-01-2009, 08:41 PM
  4. 97 GTP engine codes
    By willy4x4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 12:31 PM
  5. engine light/trouble codes
    By Jakegday in forum General Tech Discussion
    Last Post: 01-02-2009, 08:03 PM
