Thread: What gause metal is used on the SD Headers?
Results 1 to 5 of 5
  1. #1 What gause metal is used on the SD Headers?
    Jacksonville, Fl
    title^^^
  2. #2 Re: What gause metal is used on the SD Headers?
    SE Level Member fst4dr's Avatar
    Calgary
    the flanges have got to be about 3/8 and the tubing would be about 1/16 thick not sure what gauge that is maybe someone else will chime in with some more accurate numbers for you but this is what i remember from my install
    1998 4dr GTP Bright Red
    180* Stat/FWI/ZZP PCM/SD Headers/MPS 3.4/104's/6000k H.I.D/Tinted tails/Eibach's/GMPP STB/12'' Brake upgrade/18'' Ruff Black/Machined
  3. #3 Re: What gause metal is used on the SD Headers?
    Jacksonville, Fl
    Thanks . That'd be about a gauge of 16. And that's the same as a lot of other headers so that sounds right. I just know they're cheap and I'm considering them but I wanted to make sure they are not cheap due to lack of material
  4. #4 Re: What gause metal is used on the SD Headers?
    Calgary
    no they are inexpensive not neccesarlly cheap just make sure you get some good band clamps and you will be good to go but be aware that if you are lowered the down pipe is super low on these like I mean I have 1.5-2'' of clearance on the pipe until i do my engine/trans spacers this weekend
  5. #5 Re: What gause metal is used on the SD Headers?
    Jacksonville, Fl
    Ya i read a little about that. I'm not lowered as of now but i was considering it later down the road. I'll probably just go with the SD's for now and work it out later if I still want to drop an inch or 2. Thanks for the input bro
  1. Scrap metal!
    By GAFF in forum Off Topic Discussion
    Last Post: 11-24-2010, 02:09 PM
  2. Metal Clip
    By Red97GPGT in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 09:00 PM
  3. Metal Shavings
    By GTPluv in forum Off Topic Discussion
    Last Post: 04-02-2008, 11:53 AM
  4. LS1/LS2 metal oil cap overlay
    By Preotic in forum Visual/Body Modifications
    Last Post: 03-01-2008, 09:57 AM
