Thread: Help have codes po300 and po716
Results 1 to 4 of 4
  1. #1 Help have codes po300 and po716
    SE Level Member SteveCZ28's Avatar
    Dec 2010
    Greene,Ia
    I got a check engine light last nite. had them scanned today. have a po 300 which is a random misfire and a po716 which is the input turbine sensor parameter out of range
    the car runs ok. it has a stutter here and there from the randmom misfire (havent got to dig into it yet)
    but the car still drives, and shifts fine/normally. so i dont exactly know whats going on here. any information would be greatly appreciated right now
    dont know if the speedometer would be affected or not. but it still reads accuratly...i also have a bad wheel bearing too, dont know if over time it would kinda of "trick" the pcm into thinking its messed up. which i highly doubt tho
    1999 Camaro Z28
    1997 Grand Prix GTP
    1995 Dodge Ram
  2. #2 Re: Help have codes po300 and po716
    Dec 2010
    Greene,Ia
    anyone?
    1999 Camaro Z28
    1997 Grand Prix GTP
    1995 Dodge Ram
  3. #3 Re: Help have codes po300 and po716
    Clear them, check your plugs and wires/coils. The P0300 is usually ignition related. The P0716, has been found to be a bad wire, bad input speed sensor, stretched chain and or broken reluctor on the drive gear.
    Your speedo reading is taken by the VSS which is on the diff end of the trans. The ISS is reading the input shaft speed. If something is going wrong in the trans, it'll manifest itself soon. Hopefully it's just a glitch or soemthing small.
  4. #4 Re: Help have codes po300 and po716
    Dec 2010
    Greene,Ia
    which set of wires am i looking for that go to the iss???
    1999 Camaro Z28
    1997 Grand Prix GTP
    1995 Dodge Ram
  1. PO300 help
    By EJOUIE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-06-2011, 10:14 AM
  2. po716 po717
    By jayaidanericka in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-07-2010, 10:28 AM
  3. Car Codes
    By 1996pontiac in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2010, 08:23 AM
  4. My car is FU**** WTF? 48 Codes
    By Toofastgs in forum General Tech Discussion
    Last Post: 12-24-2009, 10:57 AM
  5. Error codes p0341 and po300
    By jessiinicole in forum Introductions/Noob Questions
    Last Post: 09-09-2009, 04:34 PM
