Ok short version.
ABS light would come on at random. Replaced hub it fixed it for a sort time. But it started to kick the light on at 15mph and one of the front brakes would start dragging.
Removed hub put old hub back on(now missing abs wire) of course abs light was on but brake light would be on too, restart car and brake light would go away. But non of the brakes started to drag. Left it like this for few months. Got a different hub and first 30 min of driving all was great. Turned car off went into a store came back out and started and boom abs light and a brake was dragging. Restarted car and was fine until i hit a bump abs light. Tried to reset system several times and nothing light would remain on and a brake would start to drag.
Took car to friends hows to get the body codes scanned. Left his house and what do you know. Works fine.
Nowis going on with my car with all these codes?
[PCM] P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency (Old) (History) (Immature)
[PCM] P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage (SES) (Old) (History) (Current) (Immature)
[PCM] P0332 - Knock Sensor 2 Circuit Low Input (Bank 2) (Old) (History) (Current) (Immature)
[PCM] P0706 - Trans Range Switch Performance (History) (Immature)
[PCM] P1111 - Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage (Old) (History) (Current) (Immature)
[PCM] P1573 - PCM/EBTCM Serial Data Circuit (History) (Immature)
[PCM] P1626 - Theft Deterrent Fuel Enable Signal Not Received (History) (Immature)
[PCM] P1652 - Powertrain Induced Chassis Pitch Output Circuit (History) (Immature)
[PCM] P1653 - Oil Level Lamp Control Circuit (History) (Immature)
[PCM] P1662 - Cruise Lamp Control Circuit (History) (Immature)
[PCM] P1663 - Oil Life Lamp Control Circuit (History) (Immature)
[PCM] P1672 - Low Engine Oil Level Lamp Control Circuit (Pending) (History) (Current) (Immature)
[PCM] P1673 - Engine Hot Lamp Control Circuit (History) (Immature)
[Brake] C1222 - RF Wheel Speed Sensor Input Signal is 0 (History)
[Brake] C1223 - LR Wheel Speed Sensor Input Signal is 0 (History)
[Brake] C1225 - LF Excessive Wheel Speed Variation (History)
[Brake] C1226 - RF Excessive Wheel Speed Variation (History)
[Brake] C1236 - Low System Supply Voltage (History)
[Brake] C1233 - RF Wheel Speed Circuit Open or Shorted (History)
[Brake] C1232 - LF Wheel Speed Circuit Open or Shorted (History)
[Brake] U1300 - Class 2 Short to Ground (History)
[Brake] C1265 - LR Inlet Valve Solenoid Malfunction (History)
[Brake] C1287 - Steering Sensor Rate Malfunction (History)
[Brake] C1286 - Steering Sensor Bias Malfunction (History)
[Brake] C1294 - Brake Lamp Switch Circuit Always Active (History)
[Brake] C1293 - Code C1291 Set in Previous Ignition Cycle (History)
[Brake] C1292 - (History)
[Brake] C1291 - Open Brake Lamp Switch Contacts During Deceleration (History)
[Brake] C1315 - (History)
[Brake] C1357 - (History)
[Brake] C1356 - (History)
[Brake] C1362 - (History)
[Brake] C1361 - (History)
[Brake] U1016 - Loss of Class 2 Communication with VCM (History)
[Unknown] U1064 - Loss of Communications with DIM (History) (Immature)
[Unknown] B0823 - (History) (Immature)
[Unknown] B2453 - (History) (Immature)
[Unknown] B0828 - (History) (Immature)
[Unknown] U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
[Unknown] B2806 - (History) (Immature)
[Unknown] B2739 - (History) (Immature)
[Unknown] B0608 - (History) (Immature)
[HUD] U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
[HVAC] B0367 - (History) (Current) (Immature)
[HVAC] B0363 - (History) (Current) (Immature)
[HVAC] B0441 - (History) (Current) (Immature)
[HVAC] B0446 - (History) (Current) (Immature)
[HVAC] B0361 - (History) (Immature)
[HVAC] B0365 - (History) (Immature)
for the oil lamps? i know work because they work when the car is started. But they have never been on out side of the system self test.
I can explain the hvac as my temp actuators are dead. Out side of that i have no clue. There are no blown fuses.
