Thread: 04 CompG knock Monster !!!!!
Results 1 to 13 of 13
  1. #1 04 CompG knock Monster !!!!!
    Apr 2008
  2. #2 Re: 04 CompG knock Monster !!!!!
    Jul 2008
    sumter,south carolina
    u have headers?
    02 GTP with mods 05 GP for DD
  3. #3 Re: 04 CompG knock Monster !!!!!
  4. #4 Re: 04 CompG knock Monster !!!!!
    Apr 2008
  5. #5 Re: 04 CompG knock Monster !!!!!
    Jul 2008
    hmmmm that weird.. i was gona say its false knock, headers hittin sway bar.. could still be false.. is ur front sway bar cracked possibly? how many miles? converter could be stopped up but that much knock at that low of speed seems crazy.
  6. #6 Re: 04 CompG knock Monster !!!!!
    Apr 2008
  7. #7 Re: 04 CompG knock Monster !!!!!
    Jul 2008
    its gotta be false knock... ur gettin KR with no boost... makes no sense.
  8. #8 Re: 04 CompG knock Monster !!!!!
    He has KR in boost too...
    I'd say do a couple things. Flip your motor mounts...that's free. See if it limits the movement of the motor and you might not be hitting something. Your lower mounts might be shot...another possibility. Clogged cat I ruled out since your not getting any knock once you roll into 3rd gear and the car doesn't seem to be hurting. Check for vacuum leaks...the rubber "T" fittings around the LIM, blower, etc. Also...try setting your AF to scan LTFT's and STFT's...see what those read.
  9. #9 Re: 04 CompG knock Monster !!!!!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Id check rail pressure. Whats the 02 bs1 read WOT. if its droping out of the 900's there might be a issue with fueling
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  10. #10 Re: 04 CompG knock Monster !!!!!
    Jul 2008
    have u went WOT at all since installing aeroforce? im curious to what it would say with u really gettin down on it.
  11. #11 Re: 04 CompG knock Monster !!!!!
    Jersey
    are you scanning from a dead stop?
    scanning at a roll isn't accurate
    16' wrx sti- stock
  12. #12 Re: 04 CompG knock Monster !!!!!
    Apr 2008
  13. #13 Re: 04 CompG knock Monster !!!!!
    Pennsylvania
    Around 70k, the rubber T under your snout dry rots. Check to make sure it's secure and healthy... also, if it's not working, you'd notice that the DIC's boost gauge does nothing in boost.
  1. Are the compg gtp's faster than the non compg gtp's?
    By GMCARS4LIFE in forum Off Topic Discussion
    Last Post: 03-07-2011, 09:19 PM
  2. Oct 16th Halloween Monster BASH Car Show! Hudson, MA.
    By Specter GXP in forum Shows and Events
    Last Post: 10-13-2010, 12:19 PM
  3. Frickin' Monster Truck driving around!!
    By Colossus in forum Off Topic Discussion
    Last Post: 10-10-2010, 12:50 PM
  4. Monster PARTS- A Bunch of Fools!
    By The Guz in forum The Rant Forum
    Last Post: 03-08-2009, 04:56 PM
  5. Monster PARTS- A Bunch of Fools!
    By Lion29GTP in forum Shops and Community Heroes
    Last Post: 02-11-2009, 05:12 PM
