its gotta be false knock... ur gettin KR with no boost... makes no sense.
He has KR in boost too...
I'd say do a couple things. Flip your motor mounts...that's free. See if it limits the movement of the motor and you might not be hitting something. Your lower mounts might be shot...another possibility. Clogged cat I ruled out since your not getting any knock once you roll into 3rd gear and the car doesn't seem to be hurting. Check for vacuum leaks...the rubber "T" fittings around the LIM, blower, etc. Also...try setting your AF to scan LTFT's and STFT's...see what those read.
