Thread: Stripped Cam thrust plate bolts
Results 1 to 5 of 5
  1. #1 Re: Stripped Cam thrust plate bolts
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    i used grabbits when i worked construction. same concept only you chuck them into a drill. if all else fails "turn" that screw into a flathead with a hammer and a screwdriver. takes time but its usually the best answer for torx screws.
    <MiZzBeCcA>its not rape if you yell suprise
  2. #2 Re: Stripped Cam thrust plate bolts
    For stubborn things like that I use a small chisel. Go to an edge of the bolt and hammer straight at the bolt to make a good indent. Then angle the chisel so that when you hit it..you'll hit in a counter clockwise direction. Typically this will loosen them up enough to come right out.
  1. Stripped stud with lug still attached
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 08-29-2012, 04:31 PM
  2. solution for stripped motor mount bolts
    Last Post: 07-23-2010, 01:27 AM
  3. Camshaft Thrust Plate
    By dhoeschen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2010, 07:51 PM
  4. Transmissoin pan bolt stripped
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-06-2008, 10:39 PM
  5. Alternative fix for stripped threads
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2008, 05:03 PM
