Thread: gauge installation help!!!
Results 1 to 17 of 17
  1. #1 gauge installation help!!!
    SE Level Member dbrincefield's Avatar
    Feb 2010
    Dayton
    Okay so i have an oil pressure gauge and i understand that i have to take out the oil pressure sensor on my block ad replace it with the adapter that came in the kit...but what i was curious about is when i unhook the factory sensor wont that send a code to my pcm and make my check engine light come on or is there a way around it?!?
    Also i have a boost gauge and i'm not 100 percent sure where the T-fitting taps into to read the boost!
    Thanks for all the help in advance!
  2. #2 Re: gauge installation help!!!
    Topeka, KS
    Put the boost near the Map Sensor.
  3. #3 Re: gauge installation help!!!
    Feb 2010
    Dayton
    alright thanks man...do you happen to know if i will throw a code when i plug my oil pressure sensor in?!?
  4. #4 Re: gauge installation help!!!
  5. #5 Re: gauge installation help!!!
    Feb 2010
    Dayton
    thought that was the right section!
  6. #6 Re: gauge installation help!!!
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    no it will not set a code. I have my oil psi gauge hooked up how your doing it and my plug is just chillin donw there and there is no code for it.
  7. #7 Re: gauge installation help!!!
    Feb 2010
    Dayton
    good!! thanks guys
  8. #8 Re: gauge installation help!!!
    auto parts stores sell a "T" fitting so you can hook both up if you want to, the one i bought had pics to follow if you wanted to go this route. that way the idiot light still works, but lets face it by the time the light turns on its already to late.
  9. #9 Re: gauge installation help!!!
    Feb 2010
    Dayton
    ha...true...i think it only turns on when its 5psi or less and then its just a bend over and kiss ur a$$ goodbye!!
  10. #10 Re: gauge installation help!!!
    Donating Users
    Parma, Ohio
    from what i understand the best place to hook the boost gauge is the "T" under the snout of the blower..
    2003 Subaru Impreza WRX
    2008 Saturn Aura
    2000 Bright Red GTP coupe. RIP 11/6/11
  11. #11 Re: gauge installation help!!!
    Was it really necessary to put exlaimations after the title?
    Like it's been said, leave the oil connector unplugged. I'd suggest taping it up so it doesn't get dirt and water in it.
    The best place to T is by the map sensor.
  12. #12 Re: gauge installation help!!!
    i concur on the map sensor placement as well. that way the line can continue right into the car.
  13. #13 Re: gauge installation help!!!
    Feb 2010
    Dayton
    alright thanks for the help it should be pretty easy now its just a matter of finding time to do it!
  14. #14 Re: gauge installation help!!!
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    IM subing to this just because I will hopefully be doing both of these soon as well and then I wont have to ask dumb unecessary questions
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  15. #15 Re: gauge installation help!!!
    Jul 2010
    Michigan
    Ok I do have a dumb question. You guys say that leaving the oil pressure sensor unplugged (stock one) wont do anything. However ive been being told that that metric is used by the ecm itself. Does this have any truth so if its unplugged reading nothing will the car run different. (granted hes a TA owner who has never worked on the prix)
    2005 GTP Grey
  16. #16 Re: gauge installation help!!!
  17. #17 Re: gauge installation help!!!
    Jul 2010
    Michigan
    Alright my pod cluster is arriving at my house from zzp today and the gauges will be ordered next week then
    2005 GTP Grey
  1. HID Installation
    By silvermistgt2002 in forum Visual/Body Modifications
    Last Post: 12-26-2009, 01:39 AM
  2. HUD Installation- HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 10-08-2009, 08:03 PM
