Thread: HOW to and is it HARD?
Results 1 to 14 of 14
  1. #1 Re: HOW to and is it HARD?
    May 2008
    McHenry IL
    sweet that sums it all up thanks alot man but what is the point of a 180 t stat?
  2. #2 Re: HOW to and is it HARD?
    TDCRacing
    Guest
    The theory behind the whole thermostat thing in general is more hp....will you get any or see any gains other than the temp needle not going as high...no...lol
  3. #3 Re: HOW to and is it HARD?
    PA
    Yeah, personally I used to run with a 180° stat up until recently. Anymore when I drive my car, I try to get the best mileage possible. And you will get better mileage with a stock stat. The 180° stat will cause lower mpg.
    The idea behind it is to keep the engine running cooler, thus keeping the incoming air cooler and more fuel. Some people would also put them in to keep the engine cooler to combat KR. But if you have a CAI, you won't need to worry about the incoming air so much. And if your car is modded correctly, you shouldn't have to worry about KR. So it is really a moot point.
    You can do what you want, but I will not be running a cooler stat, except for at the track.
    2001 GSE
  1. For all your hard to find car part needs!
    By Reptile in forum Off Topic Discussion
    Last Post: 05-09-2008, 09:13 AM
  2. Why is my 1st to 2nd shift so hard?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-26-2008, 08:35 AM
  3. Shifts are pretty hard...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2008, 11:13 AM
  4. hard shift between 1rst and 2nd
    By gp2004_compg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2008, 06:56 PM
