Thread: '00 Grand Prix GT intake/cleaning ?'s
Results 21 to 40 of 60
  1. #21 Re: '00 Grand Prix GT intake/cleaning ?'s
    SE Level Member blueGT00's Avatar
    Mason City,Iowa
    I would have used Synthetic every time if i had the car but we just got it about 6 months ago from her mom
    '03 Chevy Silverado 1500 Blacked Out (My Truck)
    '00 Pontiac Grand Prix Gt (Fiancee's car)
    "you have to remember women are never wrong and they have the vagina."
  2. #22 Re: '00 Grand Prix GT intake/cleaning ?'s
    Jul 2008
    sumter,south carolina
    thats understandable... my friends often ask why i spend 6-7 bucks a quart on oil... ur pics are the reason.
    02 GTP with mods 05 GP for DD
  3. #23 Re: '00 Grand Prix GT intake/cleaning ?'s
    Mason City,Iowa
    haha...thats y i use Mobil 1 Fully Synthetic in my truck ...what should i use in the car after this?i dont like changing to full synthetic unless the vehicle is under 100k...so use sythetic blend or conventional still?
  4. #24 Re: '00 Grand Prix GT intake/cleaning ?'s
    Jul 2008
    synthetic wont hurt a thing.. that a myth about it being bad on gaskets and such. if it were my car id use a cheaper synthetic since its a stock DD.
  5. #25 Re: '00 Grand Prix GT intake/cleaning ?'s
    Mason City,Iowa
    im just nervous about switching it at 173k...maybe synthetic blend?
  6. #26 Re: '00 Grand Prix GT intake/cleaning ?'s
    Jul 2008
    thatd be fine.
  7. #27 Re: '00 Grand Prix GT intake/cleaning ?'s
    Mason City,Iowa
    ill do some checking...what else should i replace when im doing it?....im replacing all gaskets and thermostat?
  8. #28 Re: '00 Grand Prix GT intake/cleaning ?'s
    regular oil is just thicker. Synthetic oil will find leaks faster becuase its thinner.
  9. #29 Re: '00 Grand Prix GT intake/cleaning ?'s
    Jul 2008
    Quote Originally Posted by blueGT00 View Post
    fuel filter.. pcv.. im assuming ur doin plugs and wires?
  10. #30 Re: '00 Grand Prix GT intake/cleaning ?'s
    Jul 2008
    so ur sayin 10w 30 conventional is thinner than 10w 30 synth?
  11. #31 Re: '00 Grand Prix GT intake/cleaning ?'s
    ok well, then thinner might not be the right word.
    Synthetic Oils do not cause leaks.
    Synthetic oils Expose leaks.
    The High detergent action of the oils(IE. higher flash point, lower viscosity) removes sludge build up in the seals from conventional oils. the sludge is a film of oil and dirt and soot from combustion, this slurry works like wet sandpaper to polish metal and wear seals. As long as crank case pressures remain stable ha ha ha no leak , but introduce a high detergent oil and now that sludge is gone allowing the leak to take place
  12. #32 Re: '00 Grand Prix GT intake/cleaning ?'s
    Mason City,Iowa
    so what shall i use?
  13. #33 Re: '00 Grand Prix GT intake/cleaning ?'s
    Jul 2008
    cheap synthetic
  14. #34 Re: '00 Grand Prix GT intake/cleaning ?'s
    Mason City,Iowa
    ha i just dont want to cause any leaks after i do this tho
  15. #35 Re: '00 Grand Prix GT intake/cleaning ?'s
    Jul 2008
    Myths About Synthetic Motor Oils
    Myth: Mobil 1 will leak out of the seals of older cars.
    Reality:
    Mobil 1 does not cause leaks. In fact, new Mobil 1 was tested in dozens of industry standard and original equipment manufacturers (OEMs) tests to prove its seal performance. It is fully compatible with the elastomeric materials from which all automotive seals and gaskets are made. If an older engine is in good condition and does not have oil leaks, Mobil 1 provides the same advantages as when used in a new engine. ExxonMobil recommends taking measures to repair the leaks, then using Mobil 1. ExxonMobil also recommends following the automobile manufacturer's manual for the proper oil to use. Also watch our answer; it's myth four of five in our online video.
  16. #36 Re: '00 Grand Prix GT intake/cleaning ?'s
    Mason City,Iowa
    I heard that using synthetic after u used conventional that synthetic will not go into all the hidding spots due to all the build up and deposits making the motor burn up?...but maybe the guy i heard it from was on crack?
  17. #37 Re: '00 Grand Prix GT intake/cleaning ?'s
    Jul 2008
    yea i wouldnt listen to him.. it has the same weight as conventional.. just has a higher viscosity rate.. i love hearin ppls myths on oils. lol. plus ur gonna seafoam anyways and clean all that gunk out.
  18. #38 Re: '00 Grand Prix GT intake/cleaning ?'s
    Mason City,Iowa
    yup ill prolly use synthetic or synthetic blend...run synthetic/bend high mileage??
  19. #39 Re: '00 Grand Prix GT intake/cleaning ?'s
    Jul 2008
    run whatever u want homie
  20. #40 Re: '00 Grand Prix GT intake/cleaning ?'s
    Mason City,Iowa
    haha sorry for all the questions!...i just want a good reliable car for her and the baby thats coming in august
  1. Grand prix GT side skirts on 97 Grand Prix SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2013, 05:17 PM
  3. Cold Air Intake on base grand prix???
    By rashan in forum General Tech Discussion
    Last Post: 09-29-2010, 01:25 PM
  4. can't find intake for my 07 grand prix!
    By Torque steer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2009, 01:56 PM
  5. short ram intake for a 2007 grand prix
    By tino153 in forum General Tech Discussion
    Last Post: 10-24-2009, 10:17 PM
