Thread: LIM Gasket leak due to Dex-Cool?
Results 1 to 12 of 12
  1. #1 LIM Gasket leak due to Dex-Cool?
    GT Level Member fri3dchick3n's Avatar
    Alaska
    I am not too sure on this topic and was probably was already solved but I read somewhere that Dex-Cool will cause a LIM gasket leak. There was a lawsuit about it I guess, And you can get some money back from having to repair that problem. Has anyone done this?
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  2. #2 Re: LIM Gasket leak due to Dex-Cool?
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    You are out of luck man....It's not totally the Dex-cool's fault that your LIM gasket leaked. The major problem with Dex-cool was it sludging up and clogging stuff up in the system. It isn't good for as long as they say it is.. They made the LIM gasket out of plastic which was pretty dumb. Between the two you will get a leak at some point. They won't cover the repair, you've gotta do it yourself it really isn't all that bad though. All the replacements are metal now so you shouldn't see the problem again even if you stick with Dex.
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  3. #3 Re: LIM Gasket leak due to Dex-Cool?
    Alaska
    Well I'm glad that its a one time fix. I can see puddles of coolant near my injectors and where the gasket is. Well, it needs to be done. Hopefully soon! Thanks for the info.
  4. #4 Re: LIM Gasket leak due to Dex-Cool?
    Jul 2010
    Holyoke, MA
    If you can see it right there then its probably coming from the Upper gasket as well and seeping through between the plastic upper plenum and the LIM
  5. #5 Re: LIM Gasket leak due to Dex-Cool?
    Alaska
    Hmm, then my car has some major gasket replacing to be done! I can also see the Blower/SC gasket torn also from a tab that is sticking out in the back. ^^
  6. #6 Re: LIM Gasket leak due to Dex-Cool?
    Jul 2010
    Holyoke, MA
    You'll be able to tell what you need when you tear it apart. I'd just buy the Felpro kit to do the Lower gasket, and hold off on buying the upper gasket until you get it off and see how it looks. I reused mine, but I'm cheap.
  7. #7 Re: LIM Gasket leak due to Dex-Cool?
    Waukesha, WI
    when i did mine, the supercharger gasket was torn and started getting sucked into the LIM.
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  8. #8 Re: LIM Gasket leak due to Dex-Cool?
    Alaska
    Ouch. Maybe I'll watch it a few more times and end up doing it. If any problems I'll just ask here like every problem I have lol
  9. #9 Re: LIM Gasket leak due to Dex-Cool?
    Waukesha, WI
    i would just get the supercharger gasket right away, its 10 bucks. i had a hell of a time finding it, autozone, advance, oreilys didnt have anything for it in their computer, carquest ftw
    RayRay
    92 Turbo miata
    02 lexus is300
  10. #10 Re: LIM Gasket leak due to Dex-Cool?
    its only a one time fix if you use an aluminum LIM gasket.
  1. 3.1 LIM Gasket Leak. What damage could already be done?
    By Eagle Soars in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-03-2011, 10:48 PM
  2. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  3. Is this the infamous LIM gasket Leak?
    By hostilehouse in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-23-2010, 08:15 PM
  4. Engine overheats, heater blows cool air, leak by egr tube
    By twillroth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-30-2009, 03:13 PM
  5. Oil Leak, Which gasket?
    By HOPPY in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2008, 01:07 AM
