Thread: Nice popping noise
Results 1 to 15 of 15
  1. #1 Nice popping noise
    Cleveland Heights, Ohio, United States
    So I drove the car today, so I took off kinda fast and i hear "pop, pop, pop" on the left side. I paniced and said OMG my transmission/engine! But I drove it for a little more and then I rolled the window completely down and noticed it was more outside the engine compartment. I'm thinking CV joint? Tie Rod?
    1998 Pontiac Grand Prix GT
    1998 Pontiac Grand Prix GTP
    2008 Buick Lacrosse Super
  2. #2 Re: Nice popping noise
    broken sway bar? busted upper strut mount?
    youve gotta look around and help us to help you.
  3. #3 Re: Nice popping noise
    SE Level Member 4boostin's Avatar
    Feb 2010
    Utah
    A similar noise happened to us...I think it was the Harmonic Balancer/bushing.
    98GS - 3" DP & Cat back, 9" K&N CIA in FW, Plog, 3.5", 180* Canned tune. 14.65 at 96.9mph, w/2.37 60ft. on G-Timer @ 4500 elev. @ 51*.
    87 Limited Turbo Regal- 12.04 @ 115 -Purchased New. Sold after 23 years and 115,000 miles
  4. #4 Re: Nice popping noise
    Willoughby, Ohio
    control arm bushings are known to pop but more around turns and bumps rather than straight lines, i would know, i got one comming apart
  5. #5 Re: Nice popping noise
    lol. I'm going to check this out tomorrow but Its only coming from the drivers side.
    And I bet one of you guys named my problem. I'll have to see
  6. #6 Re: Nice popping noise
    I live here. TLSheff's Avatar
    Jack it up and put the front end on stands, see if the wheel has any play. My hub is going out on mine and it started as just occasional popping when I would take off from a start. Now it pops and growls, gotta get some $$$ together, they aren't cheap
  7. #7 Re: Nice popping noise
    Funny thing is I got my hub done less than 6 months ago
  8. #8 Re: Nice popping noise
    Ocala, FL
    Quote Originally Posted by LowRidinCrew View Post
    Unfortunately they're known to fail that soon afterwards.
  9. #9 Re: Nice popping noise
    I found out it was a misfire -.- fail lol, So I'm ordering some spark plugs & wires and i needed a Throttle Position Sensor
  10. #10 Re: Nice popping noise
    GT Level Member jakewet28's Avatar
    Cincinnati
    *facepalm* lol
    VS Cam, SS Intercooler, Powerflow catback, SSAC headers, open cone, 180* tstat, 42.5lb injectors, 2.8 pulley, 3.29 gears, zzp pcm, all supporting mods
  11. #11 Re: Nice popping noise
  12. #12 Re: Nice popping noise
    Willoughby, Ohio
    sometimes the only way u can tell ur car is missing is the SES light blinking...idk how that could b mistaken
  13. #13 Re: Nice popping noise
    Quote Originally Posted by jakewet28 View Post
    *facepalm* lol
    right lol
    a misfire should not make a loud pop.
    i know but i did get my car stuck in snow before and had gunned it the day before
    Quote Originally Posted by CTKGP09 View Post
    My engine was blinking to come on i thought it was tweaking but i was like forget it let me get a computer read out, I bout Autolite Double Platinum sparks and a Throttle position sensor cause i needed one and now i gotta find my wires
  14. #14 Re: Nice popping noise
    Willoughby, Ohio
    good luck man hope everything gets fixed
  15. #15 Re: Nice popping noise
    Thanks and a couple hours later its done! No popping noise or putting
  1. Creaking Popping noise from front end.
    By nawarkk in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2010, 06:21 PM
  2. popping noise.
    By wlmrt6 in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2010, 11:52 PM
  3. Popping noise from passenger side when in gear.
    By aeidian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2010, 10:46 PM
  4. Popping noise from the rear
    By tjhgtp86 in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2010, 11:29 PM
  5. popping sound
    By flatblackgtp16 in forum General Tech Discussion
    Last Post: 07-30-2009, 12:15 AM
