Thread: 88 Grand Prix: Wiring Harness? Possibly alternator seized?
Results 1 to 3 of 3
  1. #1 88 Grand Prix: Wiring Harness? Possibly alternator seized?
    SE Level Member nikiyo88's Avatar
    Idaho Falls, Id
    I have an 88 Grand Prix Coupe
    Just replaced ignition module and crank sensor because it would die when warm and wouldn't start.
    ran great for 2 days.
    Now my idle is low and rumbles. Lost alot of power and can barely get up hills.
    I'm thinking i have some wires crossed and need to dig through my wiring harness or maybe my alternator seized.
    Any suggestions/opinions?
  2. #2 Re: 88 Grand Prix: Wiring Harness? Possibly alternator seized?
    St. Louis
    I would check for vac. leaks. Also, if the alt. was seized the belt would have smoked by now and broken. Pop the hood while its running and see if the alt is spinning.
    If so, take a multileter and test the battery while running. See if the voltage is low.
    Is the CEL on?
  3. #3 Re: 88 Grand Prix: Wiring Harness? Possibly alternator seized?
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    the coil packs are numbered so it shoudnt be too bad ot check your plugg wires. also it could be just bad wires, check your spark plugs too. to check the rear ones you need to remove your front engine mounts and roll the engine foward (gotta love engineering :/ )
    heres the cylinder numbering
    2 4 6
    1 3 5
    FRONT OF CAR
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  1. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  2. 1999 Grand Prix SE Need help with radio Harness
    By Xware in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2010, 08:04 AM
  3. Changing my alternator 94 grand prix
    By bud6770 in forum General Tech Discussion
    Last Post: 05-10-2009, 11:51 AM
  4. 04+ Wiring harness
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-27-2008, 03:22 PM
