Thread: Looking for evaporator tubing ends at TB
Results 1 to 5 of 5
  1. #1 Looking for evaporator tubing ends at TB
    Aug 2008
    Hamilton, OH
    I'm in the middle of doing a LIM gasket replacement. As part of that job, I had to remove the evaporator solenoid and tubing that runs across the front top of the engine.
    There's a rubber piece that two of the rigid plastic tubes go into, and in turn goes to a single nipple on the throttle body. That rubber piece is cracked, and I'm hoping someone has a part number for it. thanks.
  2. #2 Re: Looking for evaporator tubing ends at TB
    May 2008
    staten island,NY
    just replace with rubber vac hose. the dealer is going to charge you an arm and a leg. i changed mine when i went with the N* TB
  3. #3 Re: Looking for evaporator tubing ends at TB
    Aug 2008
    Hamilton, OH
    Evidently your friendly local auto parts stores don't carry much vac stuff anymore. You can get packets of multiple size parts, but you cant buy individual pieces. Plus, they carry only three sizes of vacuum hose. And they didn't carry reducers. By the time I had bought the various pieces needed, I would have spent over $10. But I couldn't buy what I needed. I was pretty disgusted.
    So I went to the dealer and bought the whole hose assembly. $20. Oh well, at least it looks original!
  4. #4 Re: Looking for evaporator tubing ends at TB
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Ed Morad.
  5. #5 Re: Looking for evaporator tubing ends at TB
    I live here. UR LOSN's Avatar
    Rockford, IL
    you dont have to have it exact. I used normal vacuum line(that will slide tightly over TB tube) into a splitter/reducer, and then just put tiny vacuum line from the reducer to the normal hard plastic line that goes over the motor.
    the stock line connectors get brittle over time, as I am sure you know now..lol
  1. How hard is it to replace tie rod ends?
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2008, 10:55 PM
  2. Painted muffler ends. Pics inside
    By Freebeer187 in forum Visual/Body Modifications
    Last Post: 11-06-2008, 04:27 AM
  3. Front ends squeaks when steering...
    By brycemassey in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2008, 06:15 PM
  4. Replies: 6
    Last Post: 04-14-2008, 11:47 AM
