Thread: ABS and Trac off lights remain on
Results 1 to 18 of 18
  1. #1 ABS and Trac off lights remain on
    SE Level Member Reddcurrlz's Avatar
    Feb 2009
    Panhandle of Florida
    Last year I had turned off the highway to look at a piece of property that had dirt roads to the house; when I got back on the highway, my ABS light came on and my Trac off light came on. When I go to push the Trac button, it won't push. I'm wondering what causes those two lights to come on? Does it mean I need brakes and then it will fix both problems? Are they related issues perhaps?
  2. #2 Re: ABS and Trac off lights remain on
    Minnesota
    Wheel hub usually is the problem. Iv had the same problem with mine for about a year now lol Just havnt got around to fixing it
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  3. #3 Re: ABS and Trac off lights remain on
    Michigan
    I agree with Rick, it is usually the wheel hub. When you replace it or have it replaced make sure to ask for a Timken. Auto Zone has them for about $135. Do not get anything from China like Dyna Pak, it will not last and has a short warranty....not worth the price or trouble.
  4. #4 Re: ABS and Trac off lights remain on
    Feb 2009
    Does the same thing cause the ABS light to stay on? They happened at the same time
  5. #5 Re: ABS and Trac off lights remain on
    Michigan
    You bet. Both systems share the same sensor.
  6. #6 Re: ABS and Trac off lights remain on
    Windsor (ON) Canada
    100% Wheel Hub...I drove around with those lights on for a while before changing them, its a very common problem. You may have days when it will go off, but if it comes back on, you need a new hub for sure.
    Have you noticed a sound coming from one up front? and does it dissapear when you take a right or left turn? If so, if the sound dissapears when....(Turning right = bad right hub) (Turning left = Bad left hub)
    Theres a really good write up on here that I used to change mine, but heres another one that Ive used. Its can be an easy job, or a bi*ch to do, depending on how seized your bolts are.
    Wheel Bearing Hub Assembly Replacement Guide - General Motors Pontiac Grand Prix GTP - Pictures & Instructions
  7. #7 Re: ABS and Trac off lights remain on
    Windsor (ON) Canada
    Here's that good write up... with all the torque specks and what-not. I have some posts in there, and a pic of how bad my hub was.
    http://www.grandprixforums.net/how-r...ubs-10985.html
  8. #8 Re: ABS and Trac off lights remain on
    Nov 2010
    Marine City MI
    Not to hijack but I have a question, my cars traction light and ABS light come on and stay on only during a cold start, after the car warms up I shut the car off and restart they go away. Also I have no noise from the front.
    99 GTP, ZZP MPS 2.9 pulley, GenIII supercharger ported & polished, machined intake W/ stage 2 intercooler, XP Cam,ZZP fuel rails, 42.5 injectors, Wizard CAI, custom headers, 3 inch downpipe, into dynomax muffler,180 stat, Northstar TB, 85mm MAF, ZZP trans, 3.29 gears, input shaft and torque converter, stock heads W/Ls6 springs.
  9. #9 Re: ABS and Trac off lights remain on
    Michigan
    Quote Originally Posted by BlackSun View Post
    One of my GPs did the same thing. This is the same problem. Yeah, sometimes you will not hear a noise because the bearing is good but the sensor is failing.
  10. #10 Re: ABS and Trac off lights remain on
    its AWDsome JarenSTi's Avatar
    Hawaii
    its not necessarily the wheel hub... mmy car had the same problem and replaced the hubs. they were still on so i got an abs scan... turns out it was a split wire in the left wheel speed censor leading towards i dont know what.
    so my advice is get an abs scan
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  11. #11 Re: ABS and Trac off lights remain on
    Nov 2010
    Marine City MI
    Quote Originally Posted by 02gpgt88 View Post
    I will do that thank you.
  12. #12 Re: ABS and Trac off lights remain on
    Michigan
    Good point. And on the flip side, on another of my GPs the hub bearing was howling but never set off the trac light or abs light.
  13. #13 Re: ABS and Trac off lights remain on
    Feb 2009
    Quote Originally Posted by Colossus View Post
    TYSM Colossus. I'll definitely check it out. Not sure I wanna tackle the repair myself though. And as far as noises? There has been a "whine" coming from the left front since I bought it 6 years ago, nobody could diagnose it though, so it's just gotten progressively worse, the more I drive it, the louder it whines. Nevertheless, I definitely wanna get certain things before I list it for sale, as well as a total detail, including the carpets and possibly the headliner replaced (it's falling)
  14. #14 Re: ABS and Trac off lights remain on
    GT Level Member Lougp05's Avatar
    Long Island,New York
    same happened to my car and still ther ejust no time to fix it, a mechanic told me it could be a bad sensor..so check that out u might possibly have a bad sensor which means u prolly have to change the hub.just saying
    <>Lou<> 05 GP,Black,8000k HIDS,FLowmaster Exhaust,Intake,20% tints.
  15. #15 Re: ABS and Trac off lights remain on
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    My trac off light wont go off. And one day i could turn off but it was while it was doing something weird and the brakes half locked up
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  16. #16 Re: ABS and Trac off lights remain on
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    the split wire thing happened to me to. its as common as a bad wheel hub. apparently it has to do with the piss poor routing of the original wiring. it bends soo much, then breaks.
    check your wires first. you may be able to fix it yourself, for near free.
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  17. #17 Re: ABS and Trac off lights remain on
    Jul 2010
    dayton ohio
    I think the only way to go is to scan the code for the issue
  18. #18 Re: ABS and Trac off lights remain on
    Windsor (ON) Canada
    There's a "Thanks" button Redd
  1. ABS/trac off lights on - 2002
    By hockeyrocks in forum Brakes/Suspension/Chassis
    Last Post: 01-11-2011, 07:44 PM
  2. ABS/Trac Off Lights on
    By trailshredder in forum Brakes/Suspension/Chassis
    Last Post: 10-31-2010, 05:59 PM
  3. ABS and Trac Control Lights On
    By itfrg in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2010, 03:07 PM
  4. Hit pothole..now ABS and TRAC OFF lights stay on
    By abuckley1290 in forum General Tech Discussion
    Last Post: 06-15-2009, 11:07 PM
  5. ABS and trac off lights
    By probuilder1 in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2009, 06:31 AM
