Thread: Window problems
Results 1 to 8 of 8
  1. #1 Window problems
    SE Level Member Robby Avery's Avatar
    Deep South Georgia
    I'm trying to figure out where to start with a problem on the windows not staying up. Could the track be off or what? The car has power windows but I can manually push the pass side front window up or down just by using my hands where do I start to fix this problem. Thanks in advance
    Girlfriend's ride: 03 Summit White Grand Prix GT 180* T-stat, Autolites, Bosch wires, Custom CAI
    My Rides: 2006 LBZ CCSB LT3 Duramax Diesel Puller/DD
    2002 LB7 Duramax Diesel CCSB LT3 to many mods to list! Work Truck/DD
  2. #2 Re: Window problems
    St. Louis
    Sounds like the regulator is shot. Common issue on these cars. Only way to fix it is to replace the regulator/motor assembly.
  3. #3 Re: Window problems
    Florida
    It's the motor/regulator for sure.
    I've replaced 5... thats what they do.
    They arent that expensive, and you can get them online pretty cheap. Just make sure you get the one that's specific for the window you're working on.
    Pop the door panel off, remove that plastic shield, unbolt the motor/regulator assemby, and disconnect it.
    And swap out the new one. Fairly straight forward, and it's way easier if you tape the window in the up position.
  4. #4 Re: Window problems
    St. Louis
    Yes, def. tape the window up, you don't want it sliding down on your hands while inside the door.
    And yea, I need one for my front pass. side again. Broke it due to frozen window. Argh!! Another 20 min. of my life I won't get back
  5. #5 Re: Window problems
    GT Level Member donmega's Avatar
    St louis, mo
    x4 regulator. easy fix hes right 20 min if you know what you're doing
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  6. #6 Re: Window problems
    Deep South Georgia
    Thanks guys for the help. Would autozone or other parts houses have the motor
  7. #7 Re: Window problems
    St louis, mo
    yea they should. may see if you can get a junkyard part they can get pretty pricey
  8. #8 Re: Window problems
    Florida
    They might...not something they would carry, they'd have to order it.
    Hell, 3 of the 5 i've bought were offa Ebay...all of them work great
  1. Help Window Problems
    By JoshsGTP in forum General Tech Discussion
    Last Post: 08-24-2010, 10:59 AM
  2. window problems
    By NomeCrusher in forum General Tech Discussion
    Last Post: 06-24-2010, 02:42 PM
  3. plz help me with my window problems
    By cavalier6908 in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2010, 08:10 PM
  4. Window Problems
    By KawaFord in forum General Tech Discussion
    Last Post: 09-24-2009, 06:26 PM
  5. Window Problems
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2008, 05:02 PM
