Thread: Awkward noise
Results 1 to 9 of 9
  1. #1 Awkward noise
    SE Level Member Vik's Avatar
    Texas
    Ok so i just started to hear this noise about a week ago coming from the front of my car. Im not sure if its under the hood or the tires. Well when im driving and i stop at either a stop sign or a traffic light everything is fine, and i do not hear any weird noise but its when i take off from the stop that i hear that noise. It kinda sounds like something is rubbing or like that noise that an old wooden house makes(kinda creaky)..and its just as i take off. It only sounds for like a second and i do not hear it anymore until i reach another stop and the same thing happens again.. Can anyone help? I can not figure out what it is. ....
  2. #2 Re: Awkward noise
    GT Level Member Mitchstrp's Avatar
    Missouri
    is it like a sex sound? thatd be an awkward noise lol.
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  3. #3 Re: Awkward noise
    Texas
    lol nice.. no its like something rubbing but only when i take off
  4. #4 Re: Awkward noise
    St. Louis
    Could be the brakes dragging a bit. Might want to pull the front calipers and grease the bolts/slides and see what that gets you. Could also be a wheel bearing going.
  5. #5 Re: Awkward noise
    Texas
    Quote Originally Posted by FordMan77 View Post
    Great thanks . I'll be sure to check that once the weather calms down a bit. Appreciate it
  6. #6 Re: Awkward noise
    Michigan
    This sounds like it could be the front struts. Pull the hood release inside the car and go to the front and pull up on the hood with out unlatching the secondary release. If there is enough force being used to lift the front of the car it may make the noise again. So yeah, front struts would be my guess.
  7. #7 Re: Awkward noise
    GTX Level Member Deimos's Avatar
    iowa
    My vote is cold weather making the noise
  8. #8 Re: Awkward noise
    Florida
    Mine does it too, it creaks like a ***** in the cold.
    It could be anything from a bad strut, to a motor mount, to the brakes grabbing a bit. If the brakes were grabbing, you should be able to feel it through the pedal some though.
    Pop the hood, grab onto the motor, and pull it forward, then let it rock back, and see if it makes the noise. If so, try to locate the noise.
    If it does it without the car rocking any, its a mount, if the car does rock, and then you hear it, it's probably a strut.
  9. #9 Re: Awkward noise
    Texas
    Thanks i'll be sure to do that
  1. Another f...in noise!
    By RyanL in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2010, 02:47 PM
  2. This noise
    By pontiackid in forum General Tech Discussion
    Last Post: 06-11-2009, 11:41 AM
  3. Odd noise, can someone help!!!
    By indybrad in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2009, 02:06 PM
  4. awkward tapping coming from motor...
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2008, 08:01 PM
