Thread: check out this GENV LIM
Results 1 to 20 of 21
foursixer check out this GENV LIM 01-11-2011, 08:14 PM
TheOtherNick Re: check out this GENV LIM 01-11-2011, 08:16 PM
foursixer Re: check out this GENV LIM 01-11-2011, 08:44 PM
matt5112 Re: check out this GENV LIM 01-11-2011, 08:23 PM
PurpleGuy Re: check out this GENV LIM 01-11-2011, 08:24 PM
PurpleGuy Re: check out this GENV LIM 01-11-2011, 08:43 PM
foursixer Re: check out this GENV LIM 01-11-2011, 08:48 PM
MidnightBlue Re: check out this GENV LIM 01-11-2011, 08:29 PM
foursixer $25.00 i hope to get... 01-11-2011, 08:38 PM
TheOtherNick Re: check out this GENV LIM 01-11-2011, 08:44 PM
matt5112 Re: check out this GENV LIM 01-11-2011, 08:47 PM
2003 SSEi Re: check out this GENV LIM 01-12-2011, 09:21 AM
foursixer Re: check out this GENV LIM 01-12-2011, 11:58 AM
foursixer Re: check out this GENV LIM 01-12-2011, 12:04 PM
BillBoost37 Re: check out this GENV LIM 01-13-2011, 07:55 AM
foursixer Re: check out this GENV LIM 01-13-2011, 03:57 PM
Bio248 Re: check out this GENV LIM 01-14-2011, 08:28 AM
BillBoost37 Re: check out this GENV LIM 01-14-2011, 09:37 AM
foursixer Re: check out this GENV LIM 01-14-2011, 07:33 PM
Bio248 Re: check out this GENV LIM 01-14-2011, 02:41 PM
Bio248 Re: check out this GENV LIM 01-16-2011, 03:26 PM
  1. #1 check out this GENV LIM
    Donating Users foursixer's Avatar
    boston,ma
    can i get some comments on my build . click on the X!
  2. #2 Re: check out this GENV LIM
    Charles City, IA
    SMGPFC Two Nipple General
  3. #3 Re: check out this GENV LIM
    boston,ma
    hillarious!!!!
  4. #4 Re: check out this GENV LIM
    Pictures by foursixer - Photobucket
    Basically someone ran plugs in the holes so they didn't have coolant flowing into the blower case and throttle body.
  5. #5 Re: check out this GENV LIM
    Never Never Land
    matt's such a nice guy postin that link
  6. #6 Re: check out this GENV LIM
    Never Never Land
    Quote Originally Posted by foursixer View Post
    can anyone advised me on the drill alky holes?
    I thought they did that in TB spacers. I could be wrong though...i dont know a whole lot about that stuff.
  7. #7 Re: check out this GENV LIM
    boston,ma
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    the holes were made for two nozzles one on each side, direct spray and not through the blower. i beleive its a zzp LIM
  8. #8 Re: check out this GENV LIM
    Banned
    Sioux Falls, SD
    On your picture 7of 7 what did they charge you to chafer it
    boston,ma
    Quote Originally Posted by miker56 View Post
    $25.00
    i hope to get better with this picture ****!
    is it better to keep the ports flowing through the TB?
  10. #10 Re: check out this GENV LIM
    Charles City, IA
    Spraying post blower is actually a little better as long as it gets evenly distb.
  11. #11 Re: check out this GENV LIM
    use the edit button. its your friend.
  12. #12 Re: check out this GENV LIM
    GTP Level Member
    Pittsburgh
    no its not the ZZP lim, its the LIM that you Got from Bill....that Hole in the last pic was for a Air Temp Sensor
    any yes the coolant and the Egr was blocked off when running the IC
    2003 SSEi,
  13. #13 Re: check out this GENV LIM
    boston,ma
    Quote Originally Posted by 2003 SSEi View Post
    wow, i had this LIM a few months well. i did not know it was bill's! i would reach out to him. i assumed this LIM is for use w/o PCV valve.
  14. #14 Re: check out this GENV LIM
    boston,ma
    so that explains one hole what is the second one for http://i1205.photobucket.com/albums/...IMG_2454-1.jpg
  15. #15 Re: check out this GENV LIM
    Len....
    Pat's wrong on this one. That didn't come from me. He probably thinks I left the LIM on the engine, but the one on there was cut for the IC core and came off before you picked it up.
    The early Gen V manifolds has the recessed area for coolant o-rings in the gasket (like a Gen 3 gasket) and the newer style of manifold had a flat top for the aluminum Gen V gasket.
    Either way, I'd suggest drilling, tapping and using 1/4" npt plugs on the coolant ports. Then take off the side cover of the LIM and port out the coolant passage from rear to front.
  16. #16 Re: check out this GENV LIM
    boston,ma
    Len....
    hey bill, the coolant ports were already tap and thread. i can probably take some better pictures. am lost with your statement, "Then take off the side cover of the LIM and port out the coolant passage from rear to front". what side cover are you refering too? what generation is my LIM and how do i port the passage ways? is there a write up on this?
  17. #17 Re: check out this GENV LIM
    on the passenger side of the lower intake, there is a cap with two 10mm bolts. take that off and grind out some of the middle divider. this will allow more coolant to flow through that little section. the reason behind why you would do this is because when you close up the coolant ports going to the blower and throttle body you lose a marginal amount of flow to the rear head. to make up for it you open up the side of the lower intake coolant port a little.
    make sense?
  18. #18 Re: check out this GENV LIM
    8mm bolts Nick..
  19. #19 Re: check out this GENV LIM
    boston,ma
    make sense?
    so, where the bolts are located is that the inlet leading toward the rear bank. do i have to port the outlet also then, if so where is the second area to be ported. but wait, if the coolant ports are already tapped and threaded, the port reference to bio might already been done. can anyone provide me a link to draw comparison.
  20. #20 Re: check out this GENV LIM
    ....i dont even own the car anymore to reference, it was an educated guess that everything in the engine bay is 10mm minus a few 8/13/15mm scattered about.
    jerk.
  1. Need pcv help for IC'd GenV swap
    By 00gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 04:44 PM
  2. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
