yes, so long as your're not leaking anymore, just get enough of the plugs cleaned up and all the coolant you can out and do everything in your power to get it going. starter fluid if you need. once it's running it's gonna burn/blow all that sh1t out.
also, when i had this problem (before the engine blew haha), it took many many many tries to get it to crank up because the PCM apparently had to re-configure as the burning coolant had knocked it out of whack i suppose. the reason i say this is because once it started running, it ran like crap and sounded like it kept choking out but it eventually sped up and smoothed out, gave one BIG rev and then purred like a kitten. so don't freak out if at first she doesn't crank or cranks and runs like crap. give it time to get it's numbers straight.
