Thread: change low beam daytime running lights
Results 1 to 19 of 19
  1. #1 Re: change low beam daytime running lights
    Dec 2010
    earth
    OK . the Headlight switch it is. Now can I pull a fuse to stop the lights from flashing when I remotely lock the car?
  2. #2 Re: change low beam daytime running lights
    Never Never Land
    theres a link around here...ill find it...i had to find it for miker56 last night too...its in the owners manual also.
  3. #3 Re: change low beam daytime running lights
    Never Never Land
  4. #4 Re: change low beam daytime running lights
    Never Never Land
    You know how to disable the drl's right?
  5. #5 Re: change low beam daytime running lights
    Dec 2008
    Lawndale, CA
    Use backinblack's page for reference to disable the DRL's. He has a lot of information in there as well if you want to disable the automatic headlight feature and manually control rhem.
    Headlamp Control
    Also you can reroute the DRL's to the fogs.
    DRL circuit Re-route to fog lamps
    You can do this to have the corners flash instead of the headlights to not burn out the ballasts.
    ClubGP:
  6. #6 Re: change low beam daytime running lights
    Dec 2010
    earth
    Thanks guys. I will read these and try one. I will post back to let you know if I succeeded.
  7. #7 Re: change low beam daytime running lights
    Dec 2010
    earth
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    I am trying to find out.
  8. #8 Re: change low beam daytime running lights
    Never Never Land
    when you open the driver door thers a little cover thingy. pop that off and inside is a heat sink with a connector on it..disconnect it and done....ive had mine like that for quite a while and it works fine. I'm sure theres other ways but I think thats the easiest.
  9. #9 Re: change low beam daytime running lights
    Dec 2010
    earth
    Thank you. will do
  1. 02 GTP Daytime Running Lights
    By techweenie in forum Audio, Security & Visual Electronics
    Last Post: 05-05-2010, 06:39 AM
  2. daytime running lights
    By 03renegade800 in forum General Tech Discussion
    Last Post: 08-16-2009, 07:06 PM
  3. A/C and Daytime running lights
    By hydrashok158 in forum General Tech Discussion
    Last Post: 08-14-2009, 09:06 AM
  4. How to disable daytime running lights.
    By ChvyTrcksFrdScks in forum How To Write-Ups/Tech Tips
    Last Post: 05-09-2009, 04:15 PM
  5. Daytime running lights
    By Girevik in forum General Tech Discussion
    Last Post: 01-05-2009, 12:40 PM
