Thread: change low beam daytime running lights
Results 1 to 19 of 19
  1. #1 Re: change low beam daytime running lights
    Dec 2008
    Lawndale, CA
    Use backinblack's page for reference to disable the DRL's. He has a lot of information in there as well if you want to disable the automatic headlight feature and manually control rhem.
    Headlamp Control
    Also you can reroute the DRL's to the fogs.
    DRL circuit Re-route to fog lamps
    You can do this to have the corners flash instead of the headlights to not burn out the ballasts.
    ClubGP:
  2. #2 Re: change low beam daytime running lights
    Dec 2010
    earth
    Thanks guys. I will read these and try one. I will post back to let you know if I succeeded.
  1. 02 GTP Daytime Running Lights
    By techweenie in forum Audio, Security & Visual Electronics
    Last Post: 05-05-2010, 06:39 AM
  2. daytime running lights
    By 03renegade800 in forum General Tech Discussion
    Last Post: 08-16-2009, 07:06 PM
  3. A/C and Daytime running lights
    By hydrashok158 in forum General Tech Discussion
    Last Post: 08-14-2009, 09:06 AM
  4. How to disable daytime running lights.
    By ChvyTrcksFrdScks in forum How To Write-Ups/Tech Tips
    Last Post: 05-09-2009, 04:15 PM
  5. Daytime running lights
    By Girevik in forum General Tech Discussion
    Last Post: 01-05-2009, 12:40 PM
