Thread: ignition problems...i think?
Results 1 to 3 of 3
  1. #1 ignition problems...i think?
    Indiana
    Hello.
    I have a 99 gt. Ive only had it about a month and it occasionaly doesn't like to let the key turn all the way back to release. With a little playing around it'll finally turn all the way. Well today, it stopped being so nice and no matter what I've tried, I cant get the key to turn all the way off to release key.
    I called dealer and they suggested spraying a little lubricant or silicone inside the tumbler (if I ever get the key out) until I can get it in to them.
    And I have tried several different keys, so I know that it is not just one key causing an issue.
    I didn't know if anyone eles has had this issue? I'm hoping its something simple and a rather easy fix.
  2. #2 Re: ignition problems...i think?
    Donating Users
    South Deerfield, MA
    Tilt your steering wheel all the way up. Pull the lever for the tilt wheel off. Take the two torx screws off of the bottom of the steering column and remove the cover they were holding on. Next to the ignition, you will see a white device about 3-4 inches long that is held in by one screw and a clip. Unplug the wire from that and remove it. Put everything back together.
    I just went throught the exact same problem with mine and did this a few days ago. This is the shift/park interlock that doesn't allow you to take the key out of the ignition unless the vehicle is in park. It wears out and won't let you take the key out even in park. The only drawback to removing it is that you can now turn the ignition all the way off and remove the key no matter where the shifter is.
    Until you can do this, there is a hole below the ignition. Push a pen or something in there to hit the release button and your key will come out.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: ignition problems...i think?
    Donating Users
    South Deerfield, MA
    Read this thread:
    http://www.grandprixforums.net/i-can...tion-6277.html
    There is a picture of the part to remove.
  1. Ignition switch problems
    By eric potter in forum Introductions/Noob Questions
    Last Post: 12-09-2009, 04:09 PM
  2. ignition problems
    By 0LmtdGP3800 in forum General Tech Discussion
    Last Post: 06-21-2009, 06:07 PM
  3. Possible Ignition control module problems?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2009, 05:04 PM
  4. Ignition switch problems
    By speedracer88 in forum General Tech Discussion
    Last Post: 01-18-2009, 08:39 AM
  5. Ignition Problems
    By iflycessnas05 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2008, 08:47 AM
