Thread: 3800 Engine swap question (lesabre to GP)
Results 1 to 12 of 12
Threaded View
  1. #4 Re: 3800 Engine swap question (lesabre to GP)
    SE Level Member 1gr869's Avatar
    Dec 2010
    Minnesota
    We are using the 03 trans with the 98 pcm. You say we need an 03 pcm. Would we need a GP pcm or a lesabre pcm? We were told by a couple of poeple that the 03 trans would work fine in the 98; only the gear ratio would be different. Can we reprogram the pcm with a tuner program?
    The code on the scanner is P1810.
  1. engine swap question!
    By gagemonster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2010, 10:52 PM
  2. 3800 Series 2 swap
    By Condor120 in forum General Tech Discussion
    Last Post: 04-25-2010, 05:18 PM
  3. 3800 engine swap
    By M.$tErNeR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-26-2009, 05:26 PM
  4. engine swap question!!!!
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 12:27 PM
  5. 1988 Buick LeSabre T-Type L67 swap
    By Rocketman69 in forum GM H Body
    Last Post: 08-07-2008, 12:12 AM
