Thread: 3800 Engine swap question (lesabre to GP)
Results 1 to 12 of 12
  1. #1 Re: 3800 Engine swap question (lesabre to GP)
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    What trans and pcm are you using? 98 Pcm cannot work with a 03 trans and Vs versus. You will need a 2003 pcm. Also if it came from a lesabre Id think it has a 3.05 Gear ratio and not the 3.29 in your GT(not 100 percent sure)
    If your still using the stock trans and stock PCM you need to swap out the maf sensor to your 98 if your using the 03's. They are different and the maf sensor will play havic on trans line pressure
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  2. #2 Re: 3800 Engine swap question (lesabre to GP)
    SE Level Member 1gr869's Avatar
    Dec 2010
    Minnesota
    We are using the 03 trans with the 98 pcm. You say we need an 03 pcm. Would we need a GP pcm or a lesabre pcm? We were told by a couple of poeple that the 03 trans would work fine in the 98; only the gear ratio would be different. Can we reprogram the pcm with a tuner program?
    The code on the scanner is P1810.
  1. engine swap question!
    By gagemonster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2010, 10:52 PM
  2. 3800 Series 2 swap
    By Condor120 in forum General Tech Discussion
    Last Post: 04-25-2010, 05:18 PM
  3. 3800 engine swap
    By M.$tErNeR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-26-2009, 05:26 PM
  4. engine swap question!!!!
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 12:27 PM
  5. 1988 Buick LeSabre T-Type L67 swap
    By Rocketman69 in forum GM H Body
    Last Post: 08-07-2008, 12:12 AM
