Thread: Misfiring HELP!!!!
Results 1 to 14 of 14
  1. #1 Misfiring HELP!!!!
    Dec 2010
    Houston
    hello all im new to this tread and I was having problems with my grand prix misfiring. I recently replaced the pcv valve, spark plugs, wires and cleaned the throttle body i Keep hearing that it could be my coils i just want to get other options before i decide to replace them. When I start the car its turns on quick but shakes while idle when i give it boost like getting on the highway is when it begins to misfire mainly between 50-60 some one please help
    thanx oh and by the way its an 07 3.8l sc
  2. #2 Re: Misfiring HELP!!!!
    please post in the correct section next time.
  3. #3 Re: Misfiring HELP!!!!
    Charles City, IA
    What cylinders is it missing on?
    SMGPFC Two Nipple General
  4. #4 Re: Misfiring HELP!!!!
    St. Louis
    Get it scanned for codes. That may tell you which cylinders are missing. Also, check to be sure you didn't cross any wires when you replaced them. I know it sounds dumb, but its any easy thing to check.
    Jay
  5. #5 Re: Misfiring HELP!!!!
    Dec 2010
    Houston
    ok when i got it scanned it read P0300 which is a multiple or random misfire.i also checked the wires and they look as to be in the correct order thanx
    Last edited by Grandprix07gt; 12-31-2010 at 01:59 PM. Reason: i also checked the wires and they look as to be in the correct order thanx
  6. #6 Re: Misfiring HELP!!!!
    SE Level Member RideMr2's Avatar
    Memphis
    I am having this same issue, code P0300, on my 2007 GT.
    The dealership replaced the entire supercharger assembly, rocks at idle noise.(warranty)
    They also replaced the cat converter for code P0300, but this did not fix the problem.(warranty)
    My check engine light starts to flash when the boost gauge(DIC) is about half way.
    Back off the throttle and it runs fine again.
    My plugs and wires are ac/delco professional, changed maybe 2 months ago.
    I do have MSD coils, I am putting my stock coils back on today to see if that does anything.
  7. #7 Re: Misfiring HELP!!!!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    MSD coils suck. But I doubt its causing a random. Id look at the ICM
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: Misfiring HELP!!!!
    GT Level Member Mitchstrp's Avatar
    Missouri
    happened to me, my tuned pcm was bad. did you recently get a canned tune?
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  9. #9 Re: Misfiring HELP!!!!
    Memphis
    Stock coils back on, this problem is fixed.
    Suggest OP replace coils.
  10. #10 Re: Misfiring HELP!!!!
    Dec 2010
    Houston
    My engine is stock as of now but I'll try the coils and we can go from there and I'll check the ICM
  11. #11 Re: Misfiring HELP!!!!
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  12. #12 Re: Misfiring HELP!!!!
    Dec 2010
    Houston
    no, no luck yet. i checked the coils checked my icm replaced wires and plugs replaced pcv , i cleaned throttle body still no luck gotta check ijectors that would probably by my last option. but the thing is im not getting an check engine light anymore but it still misfires andAT TIMES CAR RUNS VERY SLUGGISH. and rides rough on take off.
    BTW sorry it took so long to reply
  13. #13 Re: Misfiring HELP!!!!
    Aug 2008
    Fayetteville, NC
    still haggling mine too...
  14. #14 Re: Misfiring HELP!!!!
    Dec 2010
    Houston
    well i purchased the injector cleaning tool from snap on and i feel it really cleaned my system. car is running a whole lot better havent had problems since (cross my finger) try that a local shop might be able to do it for ive heard $100 but you might find a better deal good look keep me updated
  1. misfiring
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2010, 09:22 PM
  2. Misfiring
    By Kazmoe in forum General Tech Discussion
    Last Post: 02-20-2010, 07:10 PM
  3. Misfiring
    By Dropped GP GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2009, 07:15 PM
  4. need help!! misfiring???
    By icolex1 in forum General Tech Discussion
    Last Post: 02-26-2009, 03:49 PM
  5. Misfiring?
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2008, 09:33 PM
