Thread: Misfiring
Results 1 to 13 of 13
  1. #1 Misfiring
    SE Level Member Dropped GP GT's Avatar
    Dec 2008
    Wyoming, MI
    I have a 97 GT and the number one cylinder is misfiring. I swapped injectors, swapped spark plugs, tested to see if it has spark when it is missing and it is, checked for vacuum leaks and everything. I bought a code scanner and got these codes. p0301- cylinder no. 1 misfire, p1200 fuel injector control circuit, p0441 emission purge solenoid. Ok so i replaced the purge solenoid and nothing. Whats weird is the car ran fine 2 weeks ago, i started it yesterday for the first time and the number one cylinder will not fire. can anyone tell me where the fuel injector control cicuit is and how to fix it?
    thank you for your response and time to review this
  2. #2 Re: Misfiring
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    very interesting, i always thought the injectors were ran off the computer...i never heard of that code, did u check compression? i would start there. maybe a cam sensor? also i have had 3800 codes come up for lets say misfire number 3 but i know it was misfiring on more than just 3.... is your car for sure misfiring just on number 1?
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: Misfiring
    Check the plug wires...change them...then check the coils...as for the injector...not sure...maybe check the connectors
  4. #4 Re: Misfiring
    Dec 2008
    Wyoming, MI
    well when i have the car running i went through every cylinder pulling the injector plugs, any the engine rpms and everything changes on all the cylinders but the No 1 cylinder. I just bought the plug wires and spark tested every cylinder and no problems there. Whats really wierd is all the injectors read the same voltage when i tested them. Could my computer be bad? and the code p1200 is a manufacturer specific code, what ever the hell that means, lol. i'm just getting so frustrated cause everything is checking out to be ok.
    understanding the DTC codes:
    First character stands for the system type...
    P= POWERTRAIN
    B= BODY
    C= CHASSIS
    U= NETWORK
    Second character stands for sub-systems....
    0= GENERIC
    1= MANUFACTURER SPECIFIC
    2= GENERIC
    3= GENERIC/MANUFACTURER SPECIFIC
    Third character stands for sub-systems...
    1= FUEL AND AIR METERING
    2= FUEL AND AIR METERING (INJECTOR CIRCUIT MALFUNCTION ONLY)
    3= IGNITION SYSTEM OR MISFIRE
    4= AUXILARY EMISSION CONTROL SYSTEM
    5= VEHICLE SPEED CONTROL AND IDLE CONTROL SYSTEM
    6= COMPUTER OUTPUT CIRCUITS
    7= TRANSMISSION
    8= TRANSMISSION
    Fourth and fifth characters...
    THE FOURTH AND FIFTH CHARACTERS DEFINE THE MALFUNCTION THAT HAS TRIGGERED THE DTC.
    some research i found about defining trouble codes, thought it might help everyone out if they ever needed to diagnose a problem.....
  5. #5 Re: Misfiring
    Dec 2008
    Wyoming, MI
    Ok, I am at a total lose here. I checked the coil packs, spark plug and wire, fuel injector and even the computer and still don't know why my number one cylinder is misfiring. i scanned it and came back with the same codes as in my first post in here. i unplugged my MAP sensor and started it and no change. What else is there to check that would only cause that cylinder to misfire??? PLEASE SOMEONE HELP!!!!!!!!
  6. #6 Re: Misfiring
    Dec 2008
    Wyoming, MI
    i know its on the number one for sure cause when i pull the other wires while its running the engine bogs down and there is no change when i pull the number one wire.
  7. #7 Re: Misfiring
    GT Level Member GPSims39's Avatar
    Nov 2008
    Hauppauge, NY
    hows the coolant level? may be a long shot but i had a misfire for a little while then my HG blew, ended up coolant was slowly leaking into the cyl causing the misfire, just a thought.
  8. #8 Re: Misfiring
    Dec 2008
    Wyoming, MI
    Ok i'm at a complete loss. I can't figure this damn car out. I test the compression, good there, test the camshaft position sensor and the crankshaft position sensor, both good, tested the wiring to the injector, no problems there. what the hell is going on with this thing? i see people reading this postings and no one has any ideas. please i am at my wits end.
  9. #9 Re: Misfiring
    GTX Level Member cerick08GP's Avatar
    Well I spent a few years as an electrician trouble shooting break downs. And finding intermittent and multipoint failures can get be challenging to say the least. Most people can easily find a single component that has completely failed. Anyway there comes a time you just need to start replacing stuff, or as we affectionately called it “Easter egg” the problem. I would replace the injector, even though it “tested” fine.
    And since you mentioned wiring in your last post I have a good one for you. I would burn headlights out on an old car of mine about once a month. This went on for a couple years, it got to be expensive! I attempted many times to find the cause, came up empty. Until the faithful day when enough was enough, I was going to find the problem if it killed me. So I ended up stripping back the wire harness about 4 feet, and found the wires had been cut and reconnected without insulation. Then I checked the other side, it had the same deal! Nearest I could figure some jack a$$ ripped out a security system without properly addressing the wires. With any used car it is amazing the stuff you can come across.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  10. #10 Re: Misfiring
    Nov 2008
    Hauppauge, NY
    Bro i gave you my experience, check your coolant, make sure its not slowly drinking any cause i will tell you what, you will be in for a HUGE supprise if im right.
  11. #11 Re: Misfiring
    Dec 2008
    Wyoming, MI
    i think i may have found the problem. theres no pulse at the injectors, or at the computer terminal. so i think my computer went out. any ideas on it? please let me know.
  12. #12 Re: Misfiring
    Dec 2008
    Wyoming, MI
    well i fixed the problem. it WAS the computer. zzp and everyone else i talked to said it wasn't. got a new computer and runs like a new car. Thanks everyone for some of your ideas and stopping to check out my post. HAVE A GREAT NIGHT EVERYONE
  13. #13 Re: Misfiring
    Wausau, WI
    by the way, asking zzp for advice often times = fail
  1. *HELP*car stutters and feels like misfiring above 50% throttle
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2009, 01:47 AM
  2. need help!! misfiring???
    By icolex1 in forum General Tech Discussion
    Last Post: 02-26-2009, 03:49 PM
  3. misfiring?, hesitating? valve lash?
    By icolex1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-26-2009, 08:03 AM
  4. Misfiring?
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2008, 09:33 PM
  5. Help!! '01 GTP misfiring/idiling rough at startup!!
    By fatride99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2008, 06:20 PM
