Thread: A/C leak making a fool out of me!
Results 1 to 14 of 14
Threaded View
  1. #1 A/C leak making a fool out of me!
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Solved! See new post(s).
    My 1999 Grand Prix GTP has had a bad A/C leak since I've owned it. (Bad as in it pisses all your 134a out in under an hour.) You'd think a leak this large would be easy to find. Today, I tried UV dye/134a combination and a small UV light. Nothing. Also tried the soap and water method, no bubbling anywhere.
    When I try listening for the noise, it seems to be very close to the accumulator. I saw some bright green UV dye around one of the connections, so I replaced the accumulator and o-rings and repeated the process. Again, noisy leak. Felt around with my hands around all the A/C lines, hoses, fittings and connections. Can't feel or see a damn thing. The only A/C part that I can't see well in the vicinity of the hissing is the condenser. I know the condenser is a big PITA to pull out to get a good look at, so hopefully that's my last option. Looking at the front of the condenser, I don't see any signs of leaking or damage. Nothing from the side as far as I can see, either.
    If you have any opinions, suggestions, or advice, please share.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. figure it out fool!
    By Noel H in forum Engine
    Last Post: 05-05-2011, 11:17 PM
  5. Making my GTP Look better
    By iQuallzey in forum Visual/Body Modifications
    Last Post: 05-08-2010, 05:47 PM
