Thread: Updated: P0455 - EGR Self-Delete?
Results 1 to 8 of 8
  1. #1 Updated: P0455 - EGR Self-Delete?
    Pennsylvania
    Hey fellas. Scanned the '04 GTP tonight:
    P0455 Evaporative Emissions System Leak Detected - Gross Leak/No Flow
    No visible leaks or disconnections anywhere. Gas cap is in good condition.
    So, do I have to replace a part? Take off the EGR and clean it (if so, best method?)?
    Anyone have a general troubleshooting guide (checked gpona's manual, recommended some kind of smoke test to start troubleshooting... so I guess that would mean taking it to a dealership)... like a list of likely/cheap replacements or tests?
    Thanks in advance!
    Edit: Further research seems to indicate that the "evap canister vent solenoid valve" located in the driver's side rear fender gets dirty and can be cleaned by removing the wheel, wheel well, pulling the thing out, and hitting it with compressed air and carp cleaner. At least, I guess this is something that's almost free to try before throwing money at it. GM Part# 25932569 EVAP VALVE... in case I break or just need to replace it after all.
    No time to do it until Saturday, so still open to suggestions.
  2. #2 Re: P0455 - EGR Self-Delete?
    GT Level Member GrandPrixSE's Avatar
    Jun 2010
    Indy
    Quote Originally Posted by SlowNA06 View Post
    Thanks in advance!
    I was having an problem with my EGR.. But I did what someone told me and all it good currently! I just sprayed the heck outta the EGR with carb cleaner and took a few Q-Tips and cleaned her out and it seemed not to work on the first run, but after a few mins a start and go, it came back to life and works fine for now.
    So Clean it with some carb cleaner and grab some Q-tips and a few shop rags and go to town!!!
    2000 Buick LeSabre Custom - 3800 Series II V6
    1998 Buick LeSabre Custom - 3800 Series II V6 ​SOLD!
  3. #3 Re: P0455 - EGR Self-Delete?
    Pennsylvania
    I've never touched the EGR before - do I need to replace a gasket or anything when I pull it out?
  4. #4 Re: P0455 - EGR Self-Delete?
    Jun 2010
    Indy
    Just depends on if the gasket comes off with the EGR.. Mine didn't, so I just used some high temp rtv stuff and slaped it back on. I did buy a new gasket just in case the old one was shot, but it was just fine!
    So go buy a gasket and some high temp rtv, and pull the egr off, if the old gasket stays put, then inspect it for tears or cracks, if you don't see any, you should be good.
  5. #5 Re: P0455 - EGR Self-Delete?
    Charles City, IA
    The EGR is not part of the evap system. I would take it to a shop and have them hook up a smoke machine to it to find the leak. It will save you days looking and should not cost too much.
    SMGPFC Two Nipple General
  6. #6 Re: P0455 - EGR Self-Delete?
    Pennsylvania
    Update:
    *Fresh spark plugs
    *Fresh oil, filter
    *Cleaned up around filter area w/simple green
    No more code. ? None of those things should have fixed it. I'm almost angry that I didn't fix it with anything that makes sense.
  7. #7 Re: Updated: P0455 - EGR Self-Delete?
    GT Level Member neel2008's Avatar
    Huntington, IN
    1. buy tuner
    2. throw egr in trash
    3. fill egr holes
    4. tune
    5. enjoy
    97gtp
  8. #8 Re: Updated: P0455 - EGR Self-Delete?
    Pennsylvania
    ...thanks?
  1. Trouble code P0455
    By powerranger262 in forum General Tech Discussion
    Last Post: 09-23-2014, 03:09 PM
  2. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
