Thread: glowing red exhasust manifolds!!!!!
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #1 Re: glowing red exhasust manifolds!!!!!
    Topeka, KS
    FWIW im not tuned for EGR delete. other than having a code, my car runs fine.
    Well that's kinda what I was getting at it will throw a SES light. I just didn't take the time to explain that. IE having it tuned for the EGR Delete will fix the problem.
  2. #2 Re: glowing red exhasust manifolds!!!!!
    Jul 2008
    sumter,south carolina
    i hear ya... i figure since i have airbag.. security... abs lights on... may as well have check engine on
    02 GTP with mods 05 GP for DD
  3. #3 Re: glowing red exhasust manifolds!!!!!
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    your ready for christmas!
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  4. #4 Re: glowing red exhasust manifolds!!!!!
    SE Level Member jj7ski's Avatar
    Jul 2010
    lansing, michigan
    Well the 104s are in, the coils changed. The maf I put in ws junk!! So the old one is back in. The SES light is off!!! So my guess is that it was fouled plug or that corroded coil pack. I also found and fixed and vaccuum leak. Also put in 180* t-stat. So now the next step is headers!! Thanks for the limks for the headers guys! I also had another question. How restictive is the stock down pipe when you have the cat u-bend and resinator deleted and a 3" pipe to replace all that?
  5. #5 Re: glowing red exhasust manifolds!!!!!
    Jul 2010
    lansing, michigan
    Ok I got my car scanned! I had a code for bank 1 o2 sensor lean. Misfire code for #2 cylinder. I'm assuming the plugs are fouling or its because the coil for 2 and 5 has some rust on the connector. I'm changing all the coils with some that I had from my other engine that look good! I got new iat and iacvs. Changed my maf snesor from my other engine. And for KR... I'm getting 6* of KR. I'm going to have to wait to change my pulley as I can't afford to rent a puller at this time. I'm assuming that a 3 prong pulley puller is not the best idea. And as for plugs I ended up getting autolite platinum 606s. Hopefully this help for now.
  6. #6 Re: glowing red exhasust manifolds!!!!!
    Just sand down that terminal first...see if that fixes it...that's free. As for plugs...platinums are crap when modded.
    You need a colder plug to run a smaller pulley...3.4" needs headers, a tune, autolite COPPER core 104's, and a 180* T-Stat...hell...even a stock car loves headers.
    Just sayin...I bet your plugs were bent or destroyed.
  7. #7 Re: glowing red exhasust manifolds!!!!!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    lean code=vacuum leak 99 percent of the time. Dont go WOT with those platnuims in. Im just gonna go Ahead and Subscribe to this thread. I know theres going to be carnage pictures of a poped piston LMAO
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: glowing red exhasust manifolds!!!!!
    Jul 2010
    lansing, michigan
    ok ill be taking back the 606s and get 104s. and the coils i have are free also. and as for pics of a broken engine well.......... mostly likely wont happen. anyone out there that has a 3.4 pulley and a power log i would like to get them!
  9. #9 Re: glowing red exhasust manifolds!!!!!
    Hagerstown,Md
    Quote Originally Posted by jj7ski View Post
    Well we have yet to see the cause of this cylinder 2 misfire yet. (one of the common cylinders to chip)
    Also, If your only going to a power log setup your better off with a 3.6 pulley
  10. #10 Re: glowing red exhasust manifolds!!!!!
    Jul 2008
    if u have a ZZP hub... theres a 3.4 pulley for sale in FS section. why not just get headers instead? 200 bucks shipped to ur door is a steal.
  11. #11 Re: glowing red exhasust manifolds!!!!!
    Jul 2010
    lansing, michigan
    Where do I get these headers for $200 shipped!!???? I also noticed today that the schrader valve on the. Fuel rail it seaping a bit. How much of an impact would this create with this taking in air?
  12. #12 Re: glowing red exhasust manifolds!!!!!
  13. #13 Re: glowing red exhasust manifolds!!!!!
    Jul 2008
  14. #14 Re: glowing red exhasust manifolds!!!!!
    Jul 2008
    my link is cheaper..
  15. #15 Re: glowing red exhasust manifolds!!!!!
    Hagerstown,Md
  16. #16 Re: glowing red exhasust manifolds!!!!!
    Jul 2008
    the front manifold is teh most restrictive part. leave the resonator in unless u want ur car to sound like ass.
  17. #17 Re: glowing red exhasust manifolds!!!!!
    Jul 2010
    lansing, michigan
    I already have the resinator taken out. I don't think it sounds bad. Well then headers are the next priority. From the looks of the down pipe it has to be close 3" if not at least 2.5"
  18. #18 Re: glowing red exhasust manifolds!!!!!
    Jul 2008
    its 3 inch
  19. #19 Re: glowing red exhasust manifolds!!!!!
    Well jeeves...when you get the headers...and have no converter...with whatever mufflers...it sounds like epic dog sh1t.
    Here, let me show you.
    Stock Mufflers: 2004 Grand Prix GTP Gayness
    Flowmaster Mufflers: GTP Awfulness
    Flowmaster Mufflers WITH headers: Craptastic Sounds From Your Tailpipe
    Another Awesome one...no cat, no resonator...stockers: RACEFAILPIPES
    And if you think ANY of those cars sound good...bye bye.
  1. glowing red exhaust manifolds
    By GTP Ryan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2010, 07:40 PM
  2. Exhaust Glowing Red!!!!
    By 1000PRIX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 09:32 PM
  3. Glowing manifolds, what could be the cause?
    By Blue Rebel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2010, 12:29 PM
  4. 93 grandprix Catalytic converter glowing
    By ronaldgtp in forum General Tech Discussion
    Last Post: 11-21-2009, 11:57 AM
