Quote Originally Posted by BADAZGTP View Post
Have you checked the ABS sensors on the front hubs. Mine came on a while back and while doing a inspection around the front hubs, I found part of a branch that was lodged in behind the hub and it had popped the wires out of the sensor. I'm not sure what readings they should have, but starting at the source might give you a idea. Hope my little mishap can help you. Back roads during a storm suck. That,s the only place I can figure I picked up the piece of branch.
Yeah, I checked both hubs. Neither bearings seems like it is bad. Both connectors are tight and clean. Nothing logged or anything. I have a spare hub, but I haven't changed any out because I that doesn't seem to be the problem. Last time a wheel speed sensor went bad, the scanner I borrowed pointed me to the correct hub. This time, the only code I got was the "C1236 - System Voltage Low" Just makes no sense to me....
