Thread: Taillight blow out
Results 1 to 10 of 10
  1. #1 Taillight blow out
    SE Level Member jluca's Avatar
    New York
    My right rear tail light is dead. Probably from the condensation issue. The question i am looking for help with is this... am i going to be doing a simple bulb fix or fuse fix or am i going to be buying a whole new set up for my tail. Thanks.
  2. #2 Re: Taillight blow out
    Nov 2008
    Waterloo, Iowa
    First thing you can do is swap the bulb out from the other side and see if it still works.
  3. #3 Re: Taillight blow out
    New York
    i took out the tail last night to check and it was 3/4 filled with water. had problems getting the bulbs out (probably rusted in) one broke off.
  4. #4 Re: Taillight blow out
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    pics
    silver 2003 Grand Prix GT List is on it's way to be updated
  5. #5 Re: Taillight blow out
    Nov 2008
    Waterloo, Iowa
    Use pliers or something to get it out. I had a bulb break on me too trying to get it out, one of the small ones. So get something to grip and pull it, or to break it off more.
  6. #6 Re: Taillight blow out
    One of my tails fills with water and the bulb aslpoded.
    just swapped the reverse light with the tail light for the time being.
  7. #7 Re: Taillight blow out
    New York
    new bulbs did the trick, old ones were soaked. now any ideas on how to seal this pos light up so this doesnt happen? i see a bunch of guys talking about drilling hold in the light to allow water to run out.
    2002 GTP
  8. #8 Re: Taillight blow out
    GT Level Member 99GPGTP's Avatar
    Rome GA
    drill it. or replace it
  9. #9 Re: Taillight blow out
  10. #10 Re: Taillight blow out
    SE Level Member johnniep's Avatar
    nova scotia
    I masking taped mine off and put a bead of black rubberized caulking around the edges and the inside also....and drilled 2 holes in each corner of the light ...good so far
  1. blow out
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 11-26-2009, 06:14 PM
  2. When will my transmission blow
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2009, 08:31 AM
  3. Whats Wrong Did I Blow It Up ?
    By p5773566 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2009, 06:10 PM
  4. blown 2 motors need help before i blow the 3rd
    By talonpower2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2008, 05:23 AM
