Thread: Loud moaning from power steering
Results 1 to 17 of 17
  1. #1 Loud moaning from power steering
    SE Level Member PTGsDaytona500GTP's Avatar
    Jul 2010
    Broadview Hts Ohio
    The moaning used to not be that bad bit now it seems like the moaning is really loud. Any ideas on what might be wrong/is it normal or how to quiet it down??? Thanks
  2. #2 Re: Loud moaning from power steering
    Windsor (ON) Canada
    I am going to guess and say power steering pump is going.. mine makes that sound (not as loud) occasionaly when I make turns around 90*. I changed my power steering fluid and it still makes the sound.
  3. #3 Re: Loud moaning from power steering
    I would guess the pump is going, but do yourself a favor and check to make sure you have fluid in it
  4. #4 Re: Loud moaning from power steering
    Ocala, FL
    Low fluid or a bad pump..
    Just FYI, if you buy an aftermarket pump, it'll whine even as soon as you put it on..
  5. #5 Re: Loud moaning from power steering
    SE Level Member TheManiac's Avatar
    Nov 2010
    Mentor, OH
    First step, check the fluid. Most of the time it groans, you're out of fluid. If you are out of fluid, then the next step is, finding the leak. You may want to use some engine degreaser and clean things up so you don't go chasing what you think are leaks when in reality it's just old crud.
    I've had it be the high pressure hose on two different cars and then on another car the steering rack.
  6. #6 Re: Loud moaning from power steering
    Florida
    How bout flushing it too?I had a loud whine/groan after I got my tranny rebuilt and I took it back to the guy.All he did was flush my PS fluid and it was normal again.
  7. #7 Re: Loud moaning from power steering
    Nov 2010
    Mentor, OH
    Quote Originally Posted by dmahlikGT View Post
    Not sure, how/why, but I would suspect there might have been an air pocket in the power steering system. I know when you have a empty system and you first fill it up, it takes a while to work out.
    Not sure the relation between a tranny service and PS issue...
  8. #8 Re: Loud moaning from power steering
    Florida
    I think the PS resevoir and pump sit behind the tranny and might have to be removed.Regardless I never had any PS whine issues before hand so he had to do something in order for it to act up.
    Edit:you were right I just remembered he said i had air in the system
  9. #9 Re: Loud moaning from power steering
    Nov 2010
    Mentor, OH
    AH! That makes sense. I keep forgetting the placement of the PS pump (one part of the design I am not a fan of). But I can see that now, service the trans may require removing the PS pump.
  10. #10 Re: Loud moaning from power steering
    Ocala, FL
    Possibly.. Throw a piece of cardboard under the car when you park it at night and look for anything in the morning.. Location could help you dial I'm where it's coming from.
    My gt had a ps leak.. Both the return line, and the rack itself leaked.
  11. #11 Re: Loud moaning from power steering
    Charles City, IA
    You dont have to pull the pump to get the trans off, you just unclip the lines from subframe, unless they are retarded and removed the lines.
    SMGPFC Two Nipple General
  12. #12 Re: Loud moaning from power steering
    Florida
    Yup.Then the mechanic was retarded lol
  13. #13 Re: Loud moaning from power steering
    Nov 2010
    Mentor, OH
    I have not had to trace down PS leaks on the 3800 (and I am still new to the 3800). But on two 3100 Grand Ams, the high pressure line had a pin hole leak. It was found by just following the lines and found an area heavy coated in fluid and crud. With the car running, I had someone rocking the wheels left to right. On these cars, a piece of plastic wire loom is put over the high pressure line by the factory. I began to remove it and it was at that point the leak was found instantly during a wheel movement (fluid sprayed right out).
    My experience with power steering racks is to look at the ends of the rack. Usually one end has a piece that looks like it's a plug pressed in to fit. Fluid will seap out of it when it's rusty enough. Again, having someone rock the wheels left to right, you will see fluid move out of it. Eventually, that plug will pop itself out and you'll then be spraying fluid.
  14. #14 Re: Loud moaning from power steering
    SE Level Member Vlad0691's Avatar
    Dacula, GA
    Mine whines too, but I don't wanna fix it. Might trick some people into thinking it's blown ;]
    CAI, 180* T-Stat, SD Headers, EGR Delete
    I have hazy headlights <3.
    R.I.P.
  15. #15 Re: Loud moaning from power steering
    Florida
    ^ lmao.I did that the same day I had the air in my system and when I floored it, it really did sound like a gtp haha.Do it man.
  1. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  2. Power steering ?
    By blktalon456 in forum General Tech Discussion
    Last Post: 02-22-2010, 03:39 PM
  3. ABS, TC, and Power Steering off...:(
    By nikhackgt2 in forum Brakes/Suspension/Chassis
    Last Post: 02-19-2009, 12:09 PM
  4. Power Steering
    By greengaels2 in forum General Tech Discussion
    Last Post: 12-29-2008, 01:45 PM
  5. Power Steering
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2008, 05:01 PM
